Rant about newfangled MB's: Seat time in X204 & W212 (and now W206)
gsxr
UPDATE: W206 info added, see post #37 below.
Last month I visited my sister on the east coast and got to spend some time driving their 2014 GLK250 BlueTEC (X204) and 2014 E250 BlueTEC (W212). There were a number of surprises that I wasn't expecting.
<rant>
1) MB moved the cruise control stalk BELOW the combo / turn signal switch! I mean, how stupid is this? The cruise stalk was in the same location for at least 3 decades. Really, really annoying when you are going back & forth between an older MB and newer. Don't think I'll ever get used to this. What a colossal fail.​
2) The cruise control stalk has a new "feature" which took me a while to figure out. There is a detent in the stalk travel: move the stalk slightly it increases / decreases 1mph, but push past the detent and it changes ±5mph. Not realizing this, several times I was trying to figure out why the car was going way faster or slower than intended. Dunno how I feel about this one, I might get used to it, maybe. You have to be careful to push quite gently if you expect the usual ±1mph change.​
3) The shift lever was moved to the column. I don't like this, but whatever. Seems the column shift is on many (most?) models as of roughly 2010, including the 164/166 chassis that I might own someday. The problem? The functionality is backwards! Push UP for reverse, push DOWN for forward. Kinda like relocating the cruise stalk, what the hell were they thinking? I found the backwards shift pattern infuriating.​
4) If you are reversing and open the driver door with the vehicle in motion, which I do all the time when backing into a parking space... the transmission slams into PARK. omg, what sweet hell is this? I eventually figured out you must FIRST open the driver door, THEN select reverse (pushing upward, pffft), and ignore the dire warnings that you might die... but it will allow you to back up with the door open.​
5) If you select Sport shift mode (S), this resets every time the car is shut off and next time it's back in Comfort (C). I had to select Sport every time I started the car. Why isn't this setting persistent? Google says it's related to EPA regs, since the EPA ratings are in C-mode, it must default to whatever mode the EPA tests were in. Ditto for the annoying auto start/stop function which must be disabled every time you start the car. I wonder if these settings are also persistent on ROW/European models, or if you ROW allows you to select a setting that will remain persistent.​
6) IIRC (my memory is foggy 6 weeks later), I was not impressed with the E250 shifting at times (722.9 seven-speed). It was usually ok, but sometimes there was an unexpected harsh shift. I think it was related to slowing down and accelerating, like after you turn onto a side road. I expected better from a fancy electronic transmission that's supposed to read my mind. Car has 110kmi and supposedly had the transmission serviced at 90k.​
7) The E250 has "dynamic LED" headlights which seemed ok on low beam. But when selecting high beam, there was a loooooong delay before high beams would engage. Then it appeared like a motor moved something, and the beam gradually raised upward. Very bizarre. And I hated the delay. Not sure if this is another "feature" (maybe adaptive high beam assist?), also not sure if it could be disabled. High beam illumination wasn't great either (see memory note above). I'd need to drive at night again and pay more attention, I only spent 30 mins driving this car at night. It seems LED's are the "upgraded" lights vs bi-Xenon? The 2014 sales brochure isn't clear. IIRC, "Intelligent Light System" (ILS) stamped on the headlamp assembly, but I'm not sure if ILS is enabled, or if that is a Euro-only thing enabled via software like on the W211? My BIL commented that he thought the X204 bi-Xenons were visibly better than the W212 LED's. I wasn't there long enough to compare. My initial impression of LED's was "meh". Maybe newer ones are better. It wasn't like the W211 bi-Xenons with ILS (enabled via SDS Developer Mode), those 211 ILS lights are amazeballs.​
8) One or both of cars had active lane-keeping assist, which didn't work half the time (I purposely drifted across painted lines to test), and sometimes when it did work, the response was more annoying than helpful. I might get used to it, but could probably live without it. I didn't get to try the Active Park Assist. Also didn't drive enough in traffic to play with Distronic.​
9) The seat belts on the 212 do a weird pre-tension thing as part of the PRE-SAFE® convenience function. My wife absolutely hated the pre-tension, it made her feel like the belt was going to strangle her, inducing brief panic every time. It didn't really bother me, but I am curious if this could be disabled or not.​
There were a few improvements, again I should have written this right after my seat time, so I'm probably forgetting something. The W212 analog-style fuel & temp gauges are a welcome fix to the W211's truly horrible bar graphs. The 204 and 212 both default to displaying vehicle speed in large numbers in the center display, which is fabulous... the 211 required pressing a bunch of buttons (every time you start the car!) to display MPH in the center, and the number is small & not that easy to read for old farts with sub-par vision. Factory backup cameras are nice. Overall there wasn't much on the 212 which made me think "wow, I sure like this better than the 211!". Not that I own a 211, our newest MB is still a 1997 W210.
</rant>
:oldman:
Wow what a rant about newfangled, I mean, decade old MBs! 😃
To be fair, for number 3, isn’t that how old column shift automatics operated? Move the lever up for park and down for D, 2, 1 ?
-Fellow most-modern-w210 owner. 😅😅😅
Hey, 2014 is BRAND new to me! :LOL:
Yes but. The old column shifts moved down from P --> R --> N --> D where P was at the top of the column shift movement.
Maybe (?) my brain would have handled it better if the MB column shift was:
P
R
N
D
... or something like that? Putting P/N in between is confusing to me, but pushing up for reverse and down for forward just seems very non-intuitive.
For those who haven't driven a recent column-shift MB, here's what it looks like:
:oldster:
I recently had to buy a daily after my trusty Jetta was totaled by a dump truck. I started looking at W211 & 2012+ W204/W212 and wasn't really all that impressed with the W212 either. The interior hasn't held up well at all imo. Beyond the buttons and wood, almost all cars I looked at had torn driver seats.
I don't think I could ever get used to the shifter column. It seems too out of place although to Jlaa's point the functionality didn't confuse me as much.
These seem to be more of an annoyance than useful. I couldn't tell if one of the cars I drove with the blindspot monitoring feature was faulty but it seemed to be doing its own thing. Definitely not enough for me to trust it.
9) The seat belts on the 212 do a weird pre-tension thing as part of the PRE-SAFE® convenience function. My wife absolutely hated the pre-tension. It didn't really bother me, but I am curious if this could be disabled or not.
It might be. I remember coding little things on a friend's W212 with some software that was installed on my Xentry/C4 laptop. Vediamo or Monaco? Something along those lines. I changed the turn signal count from the default 3 to 5, adjusted the fog light brightness etc. There may actually be tweaks to enable/disable certain things.
The W211 had terrible interior longevity... almost all 211 seats end up splitting / tearing. The exception seems to be the AMG interiors, which were made of something more robust. I believe the 212 is better than the 211 but may still not be up to the levels of the 124 (or even 210).
I think we'd eventually get used to it, but still be irritated every time. We might eventually get an X166 (GL/GLS) which has the column shift, but that's likely a few years away.
A number of items can be tweaked with DAS Developer Mode... quite a few nice upgrades available on the 211. I believe the 212 forces Xentry and I've never owned a 212, so I'm not sure how to execute similar tweaks. My understanding is that Vediamo is the engineering-level tool and you have to be extremely careful not to brick whatever module you are tweaking. There's apparently no safety net, nor an "undo" function. Monaco is related (more for diagnostics?), however I'm not sure of the differences between Vediamo and Monaco. I do know that Vediamo is sort of Developer mode on steroids.
I'm sure it's the same for the W212 where AMG interiors hold up better than the base models. I generally saw what the VINs decoded as "imitation leather" and they were all torn. Bit of an extreme example but...
I'm not sure if all luxury trim W212 had these but these seats seem to have held up better.
Just had a look back and it was Vediamo. Don't think I used Monaco then, it was one or the other. It sure wasn't straight forward by any means.
I'm a huge fan of the classic Mercedes cruise control stalk design, which persisted for decades. Sad to say on the w213, the cruise control is now operated from steering wheel buttons. RIP, old stalk.
OK Dave, some fightin' words here...
I'm a current owner of 2 W212 E550 (4.7L Twin turbo) 4matics in addition to a w211 E320 Bluetec and a previous w210.
Unfortunately your experience was with a facelift version that changed the cruise stalk location, added start stop, etc.
My lane assist works fine, but I seldom use it.
My main positives though are 1. I love the cut/raked look of the body. To me it is the best since the W124s and better than any since.
2. The stealthy persona, not unlike the 500E (I won't say wolf in sheep's clothing).
3. When you want to go fast, it's no muss, no fuss. The 4matic plants, and it goes. Contemporary tests were 4.3 0-60 and 12.8 quarter.
I like the W211, but not as much. The W210 was OK but definitely third in this ranking.
@gsxr Ha ha, I have a 2010 W164 and my 1998 SL and can relate to some of these “observations”…
2 - this puzzled me for a while after first owning the ML. In my SL on the rare occasions I use cruise I hold the lever in position until the desired speed is achieved.
3 - never really had a problem with this except I try to use the indicator stalk to select D etc. in the SL when I’ve not used it for a while.
6 - my ML’s shift is a bit crap and it also has what I call “roundabout lag” where you accelerate into a small gap and initially nothing much happens and then suddenly it tries to rip your head off! I had a similar thing on a previous XC90.
9 - on the ML this can be deactivated via the dash display settings. I have it on but it’s pretty pointless if I’m honest.
The shifter column, putting the car in Sport, Sport + or "Individual" and turning off the engine off function, you get used to ... it all becomes one startup sequence every time... ask me how I know... we've owned every E class since 2010 I think. I do the same in the M3 and S55 every time I get in them too, so no big deal -- Sport mode, Manual mode, traction on or off, let's go. No engine off function, which helps.
Now the fact that the engine and transmission have different plans for those various modes that they don't seem to be sharing with each other or you, and the fact that they'll conspire to override your Manual paddle shifting mode at unannounced times, well I never got used to that, which is why most of the time we're in the S55.
If I have to drive, let me drive a car that lets me actually, you know, drive the car.
Good tip about backing up with the door open though... never knew about that one.
@maw1124 brings up another one on my W164 that makes me crazy - the paddle shifters. I don't see a purpose in a vehicle like that, but more often than not, I've been going down the road and had to make a sudden lane change, for example, and hit one of the paddles when I grab the wheel. Took me a while to figure out that by continuing to punch them until it gets to "6" will put it back in "D" again. Ugh.
I never liked the w204s, cheap chassis and they rust like mad here! Even 2014 cars require complete subframe replacement due to severe structural corrosion!
I don't like w212 interiors either, very square and boxy.
I did just purchase a replacement daily driver which is a 2017 W205 C220D with factory AMG styling, wheels etc and the 9 speed transmission. That car drove really nicely the transmission is amazing. Haven't picked the car up yet I'll update my owners thread later this week with pics and details when I get it home.
I also need to rebuild the transmission in my w221 S320 as it lost gears last week.
My wife has a 2011 E550 (the last of the 5.5L normally aspirated V8s for the W212). Most of the things you point out don't bother me, either because I don't use them or I'm just used to them.
I know this makes me an outlier, but I hate cruise control. I never use it. Maybe once on the E550, just to test it out. Column shifter hasn't bothered me, but I can't say whether it's normal or not since the last car my family owned that had one was the early 80s Pontiac Phoenix my car had when I was a kid. Out of habit, I put it in Sport mode as soon as I get in, so that doesn't bother me. The interior has held up really well--our car has the seats in the bottom picture of post 7 (but we did get the interior wood replaced under warranty because it was improperly coated from the factory and faded quickly). I find it easier to drive at night than my W124s because the headlights are so much brighter. The beam moving thing always seemed like a gimmick to me, but hasn't really bothered me.
I do share some of your complaints. I don't like the transmission, as it annoys me that this car, with a 7 speed and more HP and torque than my 500E, usually feels slower than the 500E because it's like the car has to come back from a smoke break to get into a lower gear (even in sport mode). And I hate the seat belt pre-tensioning thing, which always seems to activate as I'm reaching for something. Also, our car is an airmatic, with a button to raise the car below where the sport/comfort suspension setting is. Somehow, whenever my mother-in-law visits, she always finds a way to press that unintentionally. Drives me nuts (but, really, this is a much longer conversation...).
Out of the E550, my 500E, or my 1994 wagon, if I had to choose which car to drive for pleasure and comfort, the 500E will always win. But I like the E550 too. In fact, I think we're days away from having that car for 10 years, and it has been a good car the entire time.
For me, since @gsxr rant triggered me to think too much about this, if they let M mode be "pure" the cars would be OK. The mistake seems marrying engine, transmission AND suspension characteristics into each mode. If they let you control your own transmission characteristics by selecting M, until you deselect it or the car turns off, the rest I think would be OK. But since that's buried in 3 way computer code, it's probably impenetrable. I'd expected some TCU tune would have addressed this by now, but I guess it doesn't exist. Or at least I haven't found it, not that I've been looking.
EDIT... for example, on my M3, I can manage Sport Mode and Transmission Shifts (speed + force), through individual buttons but the suspension is set from the factory to permanent stiff... so if MB would just liberate the transmission from the rest, they will have actually done something remarkable by having the engine and suspension work harmoniously... that's why I think full M mode would be the fix.
Whenever I drive my wife's E550, I put the (Airmatic) suspension in Comfort and the transmission in Sport. As mentioned, the transmission still leaves something to be desired, but I have no complaints about the suspension. It's nice that these are separate, in her car at least.
I don't like the transmission [in the w212] , as it annoys me that this car, with a 7 speed and more HP and torque than my 500E, usually feels slower than the 500E because it's like the car has to come back from a smoke break to get into a lower gear (even in sport mode).
Yes!!!!!! I feel like this is a super under-appreciated aspect of the w124 E500E - immediacy in throttle response at speed due to lack of a lockup function for the torque converter.
Plenty of folks, me included, rightly criticize the 722.3's sluggishness in downshifting, but this immediacy in throttle response, I think, totally makes the character of the car.
Most of the time, critics of the 722.3 downshifting (or, part-throttle upshifting) need to look in the mirror for the root cause of the problem: they are not using the gearshift to manually control shifting, as MB intended. Now, if they are referring to the speed of the shift after the manual command via the console lever, that's different... and yeah, the 722.3 isn't lighting quick to change cogs. But it doesn't really need to be.
:grouphug:
With my w221 down and awaiting my new to me w205, I am driving my 500E to work this week.
My work commute is approx 25 minutes and over a mountain. Very scenic area actually, the Sperrin mountains.
My 500E is a delight to drive around the sharp curves and bends. The throttle response of the n/a V8 is instant and eager. It feels like a very nimble car with the E60 suspension. Corners like a go kart and nice growl from the fox back box
:v8:
I bought a W212 E350 for my wife 10 years ago and it's now my daily driver after purchasing a 17 X166 GLS 550 for her 3 years back.
I really like the E350 but it did take some time to get used to the stalk shifter but over time I found it to be very intuitive to operate. Agree the door open while in drive placing the tranny in park is a PIA. Learned the hard way while backing out of the driveway in the fog at a good clip and locked her up good. 7 speed has been dependable as has the 276 engine with 150K on the odometer. Although there is no replacement for displacement!
Vehicle was optioned with the Bi-Xenon headlights with active curve. Great lights but could do without the curve feature when I looked at replacement cost...about $1300 a light. Does have a door in front of the bulb that lifts for high beams. I think Pre-tension seatbelts can be disabled. Saw this on the X166 command feature. My only major complaint was seat comfort. I changed the front seat bottoms to a 2016 style with fore and aft seat stitch vice side to side which shows above as a luxury trim model. What a difference. I should disclose I had back surgery in 1990. Overall great car.
X166 GLS 550 with the twin-turbo V-8 and the 9 speed is a rocket. Big step up from the GL 7speed in my humble opinion.
As the new owner of a W211 sedan, from what I’ve read the W211 is an improvement on the 210 in pretty much all ways, and arguably (depends on the person) is preferred over the 212. Some reports say that the 211 interior quality is better than the 212?
Some folks like the 211 styling better than the 212, others hate the 211 so I guess that is subjective. Personally I prefer the more character-ful lines of the 211 over the more angular/boxier 212. Even when they first announced and showed the 212, the exterior design didn’t move me.
That said, honestly the 212 feels like an evolution of the 211 to me, overall, rather than a huge step forward. The gap between the 210 and 211 feels larger to me than that of the 211 to the 212. I could be wrong on this, though.
Definitely on the 211 the AMG models have demonstrably better interior materials quality than non-AMG models. Dunno is that is also true on the 212, but I’m assuming that is also true.
To me the 211 still maintains a fair bit of the overall familiarity of controls and layout with the 124, so it was easy to adapt and learn it when I bought mine.
As far as the speed display in the center of the cluster gauge, I have my 211 set to display speed in large numbers at the center. It’s just a setting you can do using the steering wheel buttons. You can also display it in smaller characters in the status line at the bottom of the gauge, too.
There are tons of tweaks and nuances on the 211 as far as settings. It’s almost maddening to get things set up as you want them, and takes a long time. As in multiple, multiple sessions to get right.
I haven’t even gotten into the STAR C3 / XENTRY / Developer Mode tweaks for it yet. This winter I will do that. This weekend I am installing a factory W211”Yurro” warning triangle in the trunk. All parts that are unobtanium in the US / comm-blocked through US dealers.
That said I’ve been very happy with my 211 so far and intend to keep it. It’s a nice companion to my E500. I’m glad I bought the 211.
I seem to recall that @jhodg5ck prefers the 211 overall to the 212.
I've owned several 210's over 12+ years, and in the past owned a 211 for several years. I'd agree with the above... 211 was a revolution vs 210, but the 212 is an evolution of the 211. The 211 also comes with at least one order of magnitude additional complexity vs the 210 for diagnostics / repair, with a plethora of computer modules, and SCN coding on some modules as well. I think the 212 is incrementally more complex vs the 211.
:nos:
As an owner of both a 1995 W124 and a 2011 E350, the differences in quality are striking. From the materials used in the interior to the suspension and overall build, the contrast is clear. My 1995 W124 is still rock solid after nearly 30 years, very minimal rust spots underneath, while the "newer" E350 has had its share of issues. The seats feel cheap, with the driver’s seat splitting at the seams, the rear subframe is prone to rusting, no thanks to probable cost-cutting (so much so that Mercedes had to extend the warranty on it to 20 years with unlimited mileage, regardless of ownership history), and the road noise is quite noticeable, not sure if this is due to my run flats. I went to change the transmission fluid and discovered the oil pan is badly rusted, which is a sharp contrast from my W124 which still uses the original transmission pan. The front shocks are shot at 100,000 miles, and I can't seem to track down replacement bump stops for the rear. While I don’t regret buying the E350, my W124 with its restored suspension is, without a doubt, the more enjoyable ride.
One day, I’d love to get my hands on a W115 and restore it just for the sheer joy of the project. However, unless Mercedes sees a significant improvement in its build quality, I wouldn’t consider buying another one. These days, it seems like Lexus offers better overall quality in their vehicles.
I took my 2011 W212 to MB Fayetteville, NC, to have the subframe checked under warranty, and thankfully, there are no rust issues. 🙏
I recently had the subframe replaced on my W212. Only 50kmi (though I know this isn’t a mileage thing). There was a rust hole about an inch big. Thankfully the warranty took care of the cost.
I bought a 2019 E450 Bi Turbo V6 Cabriolet with 6 miles in December of 2018. I love this car, but it is my wife's daily. The only thing that I do not like about it is that it has directional tires and of two different sizes. This was one car that was not part of the "honda-zation" of the brand's decision to be all things for all buyers.....which I think meant that no more cabriolet unless it was the SL and everything will be basically the same.
When they pick it up for service however we never seem to get an equivalent vehicle as a loaner. They all seem to be very pedestrian, basic mercedes cars that rival honda or toyota brands. I think they have abandoned this thinking (along with the kenny kilowatt power train obsessions).
Rant over.
Nocfn, I work part time as a valet driver for our local MB dealer. We have a small fleet of daily loaners for customers. Vehicles are not more than 2 years old and comprise C300, GLB, A220, GLC300, a few GLS 450 and maybe one S class. Main stream vehicles. I’m not sure if MB or dealers determine which vehicles are used as loaners.
Some customers do complain but hey they’re getting a free car delivered to their home to use that’s new or almost new and maybe pedestrian but steps up from a Honda or Toyota
Peter
Nothing is free. Your sentiment is noted however.
Here is the part I left off.... The serviced car was returned to us with not just a low fuel light, but a flashing low fuel light. While I would not be concerned - my wife was waiting for the late delivery of her serviced vehicle she had an appointment based on the agreed delivery. The exchange was a bit chaotic, the valet was visibly shaken and over 40 minutes late. She reportedly was agitated and quite anxious to leave. And while your personal attention, I bet exceed standards - this last event did not. The vehicle sputtered and gasped with fuel starvation as she made it into the gas pump.
I asked the service advisor why the car should ever be delivered in such a state... and he rightly said it should never be. My dealer is 27 miles away via 70 mph speed limit highway. I asked that they note the record that the tank gets filled at the dealer and I get billed if the light is on. They also perform the annual state inspection as it corresponds to the scheduled service checks. They have since added that the valet verifies the gas level before accepting the vehicle for delivery. So it should not happen again. We use the valet service, it is a huge benefit. This last time was fail, uncharacteristic but still a fail. It is my hope that the circumstance was one off, mistakes happen. I am inclined to note the miles before and after and take a trust but verify stance. I complete every service review and focus on positives, even if it is just routine stuff.... everyone gets a positive review. This, I hope is a one off circumstance. Over the years, we have had one similarly appointed vehicle loaned to us. We get spoiled of course. :rugby:
The local MB dealer here in Annapolis has an Enterprise Car Rental desk on site in their service department, and I believe they use Enterprise for "loaner" cars for owners whose vehicles are being serviced for non-waiting jobs. I could be wrong about this, but I do not believe the "service loaner" cars are MB models, but rather American, Japanese or Korean cars. I walk right by this desk on a weekly basis, walking to the parts counter to pick up my weekly MB parts order. About 90% of the time nobody is sitting at this desk.
I recall seeing this same setup at MB Houston North, when I lived there (this may have changed in the 7+ years since I moved to Maryland). And if my memory serves me, also at Don Rasmussen MB of Portland (Oregon) before I moved to Houston in 2008.
I have received new/near-new service loaner vehicles on numerous occasions -- even for periods of 3-4 hours -- from our local Lexus dealer when we have our Lexi in for service. There is no rhyme or reason to what vehicle is provided -- for taking our current IS500 or former IS350 models in for service/maintenance, I have received ES sedan models, NX SUVs and RX SUVs. Not basic models, but also not the fanciest models that Lexus makes.
Except in freezing ambient weather temperatures (when Lexus shuts down their car wash), our Lexus cars have ALWAYS been returned to us fully washed and cleaned inside and out, as well as the gas tank being filled. Our Lexus dealer is within walking distance (15 minutes walk; 5 minutes drive) of my house.
Brief update. I drove my sister's X204 (GLK) on a 5-hour road trip last weekend. Overall it wasn't bad, although I'm not sure how I'd like the seats for a trip much beyond ~3 hours. Biggest nuisance was the relocated cruise control stalk (below the combo switch, instead of the legacy position above it). This resulted in me flashing high beams at the car ahead of me, when trying to turn off cruise control via the wrong stalk. Really annoying!
The ride wasn't great either. I assume it's a combination of short wheelbase, 19" wheels, run-flat tires (no spare), and maybe stiff spring rates. On rough pavement you get bounced around more than expected with a 3-pointed Star on the hood. My wife even asked, "How come this doesn't ride like a Mercedes?" 'Nuff said. The seat heaters were weak, but I don't know if they are working normally, or if this example has one or more failed heating elements that result in weak/uneven heating.
I did find one nicety though. The button on the end of the combo switch allows a single mist/wipe, and a harder press triggers the wash cycle. Driving in light snow on a wet road, this was very convenient, compared to the 1980-1990 style combo switch where you need to rotate up/back one detent for a single wipe. I also spent a fair amount of time driving the X204 at night. The bi-Xenon headlights are GREAT on both low and high beam.
I didn't get to drive the W212 at all, no update there.
:3gears:
Gerry, just a comment from a PT employee at our local MB dealer ( also BMW, Mini & Honda at same location). I'm guessing the Enterprise desk is for body shop customers who need a car for a week or 3. Typically Enterprise is reimbursed by the customers auto insurance company up to the limits of their policy or the policy of the responsible party.
Our dealer does this in house these days. Non collision customers can reserve a free loaner vehicle while their car is in the shop. MB customers receive a Mercedes, BMW customers get a Bimmer etc. Vehicles are matched to what the customer drives, more or less. To qualify your car must not be more than 5 years old thou exceptions are made. Our loaners are 1 or 2 model years old.
You're lucky, at our dealership cars gets an exterior wash only and no gas fill up. However we offer valet service; we'll pick up your car for a service appt. and drop it off when done, usually at no charge. No distance limits. Last week I drove to Lake Placid to return a customers GLB. That's about 2.5 hours each way from Albany.
Peter
:3gears:
I've mentioned before but I'm really happy with my W212. 166K on the odo and she's been a very reliable ride. Some recent issues and maintenance planned.
1. Ordered the CPS after I had a stall at the stoplight last week. Engine stopped quickly and restarted effortlessly. No check engine or codes pulled up. Suspect CPS. Cheap $50 for Benz part. Lets see how easy it is to install...
2. Checked cam sensors for oil intrusion in connectors. 1 had early signs of intrusion. Ordered 4 as preventative measure. Also cheap.
3. 1 cam mag adjuster was leaking at seal. Replacing all 4 cam adjusters $50 for Benz part.
4. Coming due for spark plugs- PIA to install.
Overall has been a great ride but just so different compared to W124(500E), W210(E55).
.... Putting P/N in between is confusing to me, but pushing up for reverse and down for forward just seems very non-intuitive.
:oldster:... I wouldn't buy a Mercedes newer than 2010. Your shifter rant is definitely spot on!
It does remind me of a time years ago when my wife was test driving a VW Jetta wagon and the salesman was explaining all the fancy features with the transmission, sport mode, paddle shifters, etc etc and my wife looks at him and says... "All I need is P R N D... and I don't even know what N is for!"
:thumbsup2:
Another update on this topic, now including the W206 chassis:
I'm currently traveling and the rental company upgraded me to a 2026 C300 4Matic, which is $53k MSRP base price. Cool! And it only has 5kmi on it. The actual driving experience is quite good. Nice engine, transmission, brakes, steering, and overall handling. Acceleration is on par with the E500E which is impressive, although there is some turbo lag and a lack of torque. It's a "mild hybrid" with an integrated starter-generator that adds up to 20 hp and 148 lb-ft of torque in short bursts. The electrics mostly offset the lag which is nice. OTOH, the battery regen makes the brakes feel just a little weird under light to moderate braking. Not bad, just different. The seats feel a bit firm / stiff, I wonder what they are like on a long trip (many hours). The rental is a stripper without satnav, Distronic, or other goodies. Tires are 18's, with 225/45 front and 245/40 rears.
With that out of the way, the UI/UX is... IMO... pretty terrible. The LCD display for the main instrument cluster isn't bad. But the center touchscreen, and steering wheel controls, are freaking awful. I'm slowly figuring out how to use the controls but there's no excuse for making it this way in the first place. It has mostly capacitive touch controls, some of which feel like a normal button, some do not. No knobs or dials anywhere. There's a long bar below the center touchscreen with multiple sections with different virtual "buttons". This was absolutely a cost-saving initiative to eliminate physical controls. Buttons and knobs cost money. Bits and bytes do not (well, outside the programming, but that's what AI is for - right?).
Some of the annoyances I've noticed so far:
  • The cruise control stalk is GONE. It was replaced with 6 capacitive buttons (SIX!) on the steering wheel. You must push a button to enable cruise... and when you shut the car off, cruise turns off, so you must turn this back on EVERY TIME you start the car. Just like on domestic and Asian cars. Stupid, stupid, stupid. The stalk was simple, intuitive, and worked perfectly for decades. Mid-teens MB's moved the stalk to the wrong location, but at least it was still a stalk. The buttons on the W206 are an abomination.
  • Auto stop-start still exists despite the government eliminating the requirement. Maybe future models will delete it. As with cruise, you must disable this every time you start the car.
  • HVAC controls are only available via touchscreen. There's no way to rapidly change temperature setting other than to go to MIN or MAX. Otherwise, it's tap tap tap tap until you get the desired temperature, and you must take your eyes off the road to do this. Same with fan speed adjustments. The W124 can have both adjusted without taking eyes off the road.
  • Media/stereo controls on the steering wheel are also bad. There's no button or roller wheel for volume, only a touch slider that doesn't work well. Volume is on the opposite side of the wheel vs track skip/reverse, and track change is also a touch slider, no buttons.
  • Worse yet - for the media controls, track skip is only available on the steering wheel IF YOU HAVE THE MAIN DISPLAY SET TO MEDIA!! Any other setting on the main display, and to change tracks you need to take eyes off the road and find the arrows on the big center touchscreen. Inexcusably terrible. Our 2010 Land Rover LR4 has discrete buttons on the steering wheel for volume and track... can do everything without taking eyes off the road. 16 years later, Mercedes is foisting upon us a cheaper, LESS safe method of control? Just insane.
  • The base model has no satnav, so if the car travels across a time zone, you must manually update the clock. Seriously? In 2026 on a >$50k car?
  • If you select Economy or Sport modes, these reset to default every time the car is shut off (same as cruise control, and stop-start). There is biometric personalisation available, I would hope that means if an owner set it up, they could touch the fingerprint sensor and have all the settings return... but again, you gotta do this EVERY TIME YOU START THE CAR. No settings are persistent (i.e., remain in the same state they were when the car was shut off).
  • The center information display has no vehicle data available that I could find (coolant/oil/ATF temps, etc). I don't think it showed tire pressure either but need to double check on that. This information is available, why not allow it to be displayed if desired?
  • In general the touch controls on the giant tablet were not intuitive, ditto for the center info display / menu.
  • The seat adjuster controls are weird. They don't move how you expect compared to 1990's and 2000's seat buttons, despite being shaped like the seat. I also struggled to get the seat in a comfortable position.
  • As with the 204/212, the seat belts yank against you (pre-tension) when you first put them on. And to reverse with the door open, you must open the door when stopped, then select reverse. The shifter still has you press down to go forward, which I suppose I'd get used to eventually.
  • The backup camera distorts the view, I think in an effort to have a wide angle on a "portrait" display. It squishes things horizontally. Once I figured it out, it was ok, but it just looks weird. I do like that it shows "tire tracks" when backing up, helpful to align with parking space painted stripes.
It's not all bad, there are some good points. The keyless entry works very well. I like that the cluster displays what gear the transmission is in. AC worked well but it was only mid-80's which isn't a good test. USB A+C ports are available although I didn't need them. Tunk lid has a 1-button power closer. CarPlay picks up the MP3 audio about 15 seconds after power on, which is kinda slow. At times, resuming music via CarPlay is faster if you open another door, or the trunk, before getting in the car - but not always. Can't quite figure that out. Wipers work well and are silent. The car looks pretty nice. Parktronic warns you BEFORE the bumpers hit a concrete parking curb, which I really like.
Oh yeah. The audio system is pretty good, but not great. The speakers are in the vertical center of the front door. This pulls the sound stage down to your knees, not up on the dash where it belongs. It should sound like the musicians are playing live in concert on the hood of the car... not down in the footwells. It isn't bad, most people would never notice, but as a former IASCA guy it is annoying to hear that in a >$50k car. All it would take is a couple of tweeters at dash level, but MB couldn't be bothered. Sigh.
:oldman:
Dave, just be glad you didn't rent a new BMW! As mentioned I work PT at our local MB/BMW/Mini/Honda dealership so I'm familiar with the new C class. I'll make a few comments.
> as you noted in the MB the fan speed and temp. can be adjusted directly on the home page of the center screen. You don't have to move to a sub menu. In the new Bimmers you can only change the temp. directly. Fan speed changes require you pull up the Climate menu which is a very cluttered display. A real pain in MHO.
>the media volume can be adjusted without using the slider. Using the bottom right hand bar on the center screen, pushing it repeatedly on the + or - raises or lowers the volume. I will say the steering wheel slider takes a certain touch with your index finger.
> vehicle info is available in the instrument cluster using steering wheel buttons to pull up SERVICE menu which then can display oil level, coolant temp bar gauge and tire pressures.
> I like the seat control switches. I find them very smooth and responsive to use and the seat moves silently.
Peter
Peter,
Thanks for the info! You are correct, the HVAC is not in a sub-menu, but still requires taking eyes off the road and fiddling with a touch screen. Dave no likey. The media volume does have a control at the right side of the long bar below the touchscreen, but if the steering wheel volume control worked better, you wouldn't need to mess with it!
I did find the "Sport" cluster display which changes to racing red, shows HP and TQ graphs (Fast & Furious style), and a G-force meter. This also shows a boost gauge and a useless coolant temp gauge, as you cannot tell what the reading is (just a relative level between cold and hot).
Good to know about the Service menu. I'll see if I can fiddle with that before I return the car tomorrow.
:3gears:
@gsxr,
That’s a very good and informative write up on the E300 4Matic.:) At least the center screen looks to be integrated into the center dash rather well.
The screen in my 2024 Camry looks like an afterthought and sticks out at eye level. So far after 10K miles and 1 year of driving the most aggravating issue I have is the “nanny that keeps you in your lane. If a tire gets near a white line you get a beep beep beep and a tug on the wheel. Even after a year it still annoys me. I had the dealer turn it off but after a day or so it turned itself back on. Other than that it’s a great grocery getter and all around nice car. I paid $24K last May and have enjoyed the first 12K miles out of the 26.7K miles on the car at present. It’s a keeper for me.
Terry, I've driven other rental cars with the lane assist, and noticed a similar issue as you describe. The rental I drove didn't have the beep-beep, but it tugged at the steering wheel. Almost felt like the tires were following pavement imperfections, but that wasn't it. Took me a while to figure out the car was "helping" me drive! Grrrr. Fortunately, there was a button to shut this off. Problem solved. Strange that your Camry doesn't have an easy override available. Click here and see if that article helps, if your Camry has the same buttons / features...
:124fast:
:124fast:
@gsxr,
Thanks Dave, I’ll read that when I have time. BTW; My Toyota Service Manager is the one who disabled it but what does SHE know.:jono:
