6-Speed manual Conversion, only £15k!
chicky
Just wanted to share as I found it interesting, but the cost is o_O
Mercedes-Benz SL 107, W116 & W126 V8 Automatic to Six Speed Manual Gearbox
when i clicked on the link, it seems that it can be fitted on a W124036 and a R129066
Mercedes-Benz SL 107, W116 & W126 V8 Automatic to Six Speed Manual Gearbox​
This unit is designed to fit SL 107, W116 and W126 V8 Engine Models and engines with prefix codes M116 or M117.
6 cylinder and V8 Mercedes Auto 3 and 4-speed transmission from the last third of a century belong to history, power losses, consumption at high speeds and enormous wear and tear.
A few years ago, a gearbox was developed for the W113 and W111 with extra overdrive for Mercedes Pagoda, suitable for six-cylinder engines of the series M108/127/129/130 also the W198 SL300.
The Range has now expanded to cover V8 models including the W107/108/109/116/126, series engines M100/116/117/119. Offered is a complete transmission kit to perform a conversion. From shifting gate to the flywheel, reinforced clutch and propeller shaft, pedals mechanism plus more.
We use the latest generation Getrag Gearbox that can Withstand upto 700Nm or torque in short intervals or a continuous load of 550Nm
Comes with 2 year warranty and no mileage limitation.
Gearboxes are delivered in a secure wooden box.
Our pre-finished gear conversion kits contain the following necessary parts:
Kit contents:
  • • Sports transmission
  • • Flywheel *
  • • Starter ring gear *
  • • Clutch Kit
  • • Universal joint fitting
  • • Speedometer connection
  • • Pedals *
  • • Slave cylinder
  • • Master Cylinder *
  • • Console
  • • shift linkage *
  • • Gear lever*
  • • Switch Ball *
  • • Connection material
  • • Installation Instructions Parts marked with * affected vehicles of automatic conversion to transmission.
Shift Pattern
R-1-3-5
2-4-6
Gear Ratio's
1 4,002
2 2,108
3 1,380
4 1,000
5 0,780
6 0,645
Advantages of the transmission 5 plus- 1-speed
  • 60% longer translation in plus 1 low gear
  • Driving at 160 km / h with 3500 rpm. And not as before 100 km / h and 3500 rpm.
  • High switching comfort due to low operating forces, short and precise switching distances
  • Compact design, low weight
  • Very good efficiency
  • Optimal tuning and synchronization
  • Perfect gear ratio
  • More economical in consumption
  • Installation made simple, no modifications to the body
  • plug and play (fully delivered and ready to drive)
Here is an overview of all the gearbox conversions available:
  • W113 / 111 230/250/280 / SL 4/5 transition on 6 speed manual transmission, motor type M108 / 110/127/129/130
  • W113 / 111 230/250/280 / SL automatic to manual 6 speed, engine type M127 / 129/130
  • W107 280SL / SLC 4/5 transition on 6 speed manual transmission, motor type M110
  • W107 280SL / SLC automatic to manual 6 speed, engine type M110
  • W108/109 280SE/L Limousine 3.5 engine M116 4 to 6 speed manual transmission, engine type M100 / 116
  • W107SL / SLC /sedans W108/109 280SE/L 3.5 to 6.9 automatic to manual 6 speed, engine type M100/ 116 W107SL / SLC /
  • W116 / 126 all V8 engines 4 to 6 speed manual transmission, motor type M116 / 117
  • W107SL / SLC / W116 / 126 all V8 automatic to manual 6 speed, engine type M116 / 117
  • W124 500E/W129 all V8 automatic to manual 6 speed, engine type M119
  • W113SL Waxenberger Pagoda / 6.3
  • W109 300SEL Red. pork 6.3
  • R129 SL280/320 V6 & SL500 V8 automatic to manual 6 speed, engine type M112 & M113
  • W111 300 SE M 189 W201 M102 / 3 e.g. EVO 16 V coming soon
Customer Reference 6-speed transmission
“I have converted my 230SL pagoda to the 6 speed gearbox because the old 4 speed transmission demanded such high RPM from the engine. I feared this may cause future issues for my SL and I wanted more out of the car. My local specialist installed the new 6-speed gearbox and it fitted perfectly. The installation was definitely worth it, driving the 230SL is really fun now! The engine now runs at an optimal speed range between 2000 and 4500 rpm. I will not reinstall the original gearbox for now and leave it in storage. Regards CLB”
Any Questions please feel free to contact the parts team on 01789 337072 or parts@theslshop.com
The transmission is probably out of the E39 V8 cars (540i, M5) rather than the E46 (which only came in V6 straight 6). IIRC they were all Getrag units (Getrag 420G transmission - Wikipedia). Very stout, driver focused boxes — fun behind a V8. Completely transformed that SL. I’m loving all the bespoke monoblock wheels people are doing these days, like these (which were not AMG as stated) and the ones on the 300SEL restomod from Icon (Icon's LS9-Powered Mercedes-Benz 300SEL 6.3 Is a God-Tier Restomod).
Hopefully we see more such wheel shops pop up around the country. I’d have to imagine the forged aluminum billet isn’t the hard part there, as much as the machinery to laser cut it and recycle the excess.
The transmission is probably out of the E39 V8 cars (540i, M5) rather than the E46 (which only came in V6),
When did they put a V6 in an E46?? The driven man uses tremec boxes. They have removable bell houses and the shifter can be relocated into multiple positions. I've been talking to them about putting a 5 speed in my 75 XJ12. I've not decided on the gearbox yet as I'm also considering swapping the rear end to a later model XJS rear end which uses outboard brakes. I have to figure out the ratios before I decide on the gearbox.
@Bilbo107baggins,
Due to scammers new members are not allowed to use the PM/DM feature until confirmed a legit member. It may take a few posts/weeks before your allowed this feature.:)
I have a guy who can manual convert any mercedes of this era and even up to the m156 cars and its much cheaper than that.
I personally can vouch for this guy. Hes done dozens of cars so far including r129 sl, clk63, c55/c43 amg, w209 clk, w210 e55....
You mean besides Kwiek? Where is the other guy located?
