The headrests will no longer retract to the lowered position.
I have located the solenoid beneath the driver's side rear seat. With the ignition switch "on", this does not "click" when the retracting button is pressed (I assuming here that the solenoid would operate with the ignition "on" but the engine not running?).
Also, with the engine running, if I remove the "inlet" side vacuum pipe from the solenoid, there doesn't appear to be any vacuum suction on this pipe.
(In all cases, the rear blind is fully retracted).
Am I chasing two problems here, i.e. no vacuum supply to the solenoid, plus also an inoperative switch?
Any ideas, anyone?
Thanks in advance.
Any ideas, anyone?
Thanks in advance.
