Just found my gremlin on the E-420 VACUUM LEAKS!!
Guys I honestly almost walked away from this car as I have never been in a M119 powered car so thought mine was "normal".
Been storming all day here but tonight when it stopped I started poking around under the hood with a good flash light getting ready for some work on her tomorrow. While looking at the throttle cable routing up by the cowl I found a disconnected hard vacuum line that runs to a trident shaped yellow tree just behind the brake master cylinder
. So I start looking a little closer and find several vacuum lines that were only partially connected
. I then go over everything that I can easily see wash up and take a drive. INSTANT the car fires it sounds different the very slight lope at idle is gone and it just sounds suddenly MUCH sharper. Take a drive and the throttle response is light years better dead spots are gone and it kicks down in normal driving like it should
Now to get the plugs in tomorrow and make a list to order a few things like the new throttle cable to get this thing right.
MUCH better driving car now and some weird whistling noises ( weird sounds that I never would of pinned as just a vacuum leak!!)that I though were just normal are now all gone!
Been spinning wrenches for many years on stuff but till just now totally missed what was going on with this one and why it was so sluggish to respond
Anybody got an under-hood vacuum diagram for the 420 as I think I got everything but want to really look hard at it.
