.036 imported to the USA
Stevester 500E
How many .036's were imported to the USA?
I read on Wikipedia that there were 1528, but the 500eboard wiki 500E Paint Code numbers only accounts for 1506 USA .036's.
I actually meant to make a thread about it. The actual number isn't that straight forward. The number in the FAQ is based on the code in the order number. It is true that 1,528 cars were built using order number with the US based code. However, it also includes this 500E, which was built up to Canadian specification. There is always a possibility that it is an error in the ETK. The car is currently in the US, but if someone got access to CarFax they might be able to check if it was ever in Canada.
There were also 9, what appears to be pre-production, US-spec 500Es built that are not included in those 1,528 cars since they have German based order codes.
WDB1240361B328898
WDBEA36EXNB348745
WDBEA36E9NB379226
WDBEA36E0NB379227
WDBEA36E1NB510889
WDB1240361B510892
WDBEA36E7NB583975
WDBEA36E4PB837001
WDB1240361B837002
According to CarFax none of those cars got any history in North America, so they were probably never imported into the states, but from my experience with BMWs, I wouldn't dismiss these cars.
So, the numbers should look like this
Total US-spec cars built: 1,536
Total US ordered cars: 1,528
Total US-spec cars ordered in the US: 1,527
A few of those are paint code 680U (Sun Yellow). I've never seen a yellow E500E.
Just curious. Where do you dig out these vins and statistics of SA codes etc. Does someone hold the complete list of vins?
Several years ago, one of our members, overseas, created a painstaking automated process that created a list of all W124 model chassis numbers and complete data cards for every single W124 produced.
Out of courtesy to me (and to this forum), he provided me with a list of all E500E data card information, as well as the sub-set of all US data card information.
This information has been culled directly from MB EPC sources, NOT from non-MB sources. Although MB EPC data cards are not 100% perfect, they are the most trustworthy source of information about these cars. I trust MB data obtained directly from factory sources infinitely more than Russian and non-MB sources.
Thus, I put 100% faith in the information that we have provided (and that our member has augmented and also provided) in the Wiki on production numbers, interior and exterior color combinations, import numbers per country.
These sites like datamb.ru and Carfax, while good general indicators, are NOT as good as original MB factory/EPC sources. If you want authoritative data, go to the Wiki where things have been posted.
That's just the way it is.
WDB1240361B328898
WDBEA36EXNB348745
WDBEA36E9NB379226
WDBEA36E0NB379227
WDBEA36E1NB510889
WDB1240361B510892
WDBEA36E7NB583975
WDBEA36E4PB837001
WDB1240361B837002
This is great info - thanks!
Of the 9 VIN's above, six of them are North American format (WDBEA-prefix) and could have ended up in either USA or Canada. The other 3 are non-NA format (WDB124036-prefix) and were most likely not imported to USA.
The first four are very, very early production (B3xxxxx!), the next three are just early production (B5xxxxx). The last two would be early 1993 USA model year, somewhere around the 13th VIN sequentially for 1993 USA models.
Strange that there would be North American VIN formats with German order codes.
Several years ago, one of our members, overseas, created a painstaking automated process that created a list of all W124 model chassis numbers and complete data cards for every single W124 produced. Out of courtesy to me (and to this forum), he provided me with a list of all E500E data card information, as well as the sub-set of all US data card information.
Thus, I put 100% faith in the information that we have provided (and that our member has augmented and also provided) in the Wiki on production numbers, interior and exterior color combinations, import numbers per country. These sites like datamb.ru and Carfax, while good general indicators, are NOT as good as original MB factory/EPC sources. If you want authoritative data, go to the Wiki where things have been posted.
Gerry, where do you think all those datacard websites get their information? They all come from the same source, EPC. So if you have 100% faith in the data that was provided to you, you should have the same faith in what I posted here. In fact, since you got the E500E data, you can run the VINs I provided against it and against EPC to verify my claims.
Gerry, where do you this all those datacard websites get their information? They all come from the same source, EPC. So if you have 100% faith in the data that was provided to you, you should have the same faith in what I posted here. In fact, since you got the E500E data, you can run the VINs I provided against it and against EPC to verify my claims.
The problem is that many (if not most) of the "VIN translator" web sites that have been available in the past, have been very error-ridden, particularly in the translation of the option codes. This is because of varying quality (i.e. "bugs") of the code used to "scrape" the EPC and transform it into a searchable database.
I know this site you are using is fairly new, and it seems to be well done. I haven't seen any complaints about its accuracy to date. However I have seen (and experienced) significant issues with nearly all of the "prior" VIN translation web sites.
I did run all of the VINs you provided against the data I have (and with the links you provided to the web site), and it does check out -- i.e. what the web site provides/translates does jive with the database that I have.
There is no guarantee that these 9 cars you list were actually brought into the US (confirming the point you and gsxr made). It looks to me that the first seven of the nine far pre-dated any "officially" imported US models, and were very very early in the model/production run.
The first chassis number you provided (328898) was actually the eighth 500E ever produced; the second chassis number was the 45th car in production -- there is no way these early cars would have been brought into the US. The second car (and several others, as GSXR states) does have a US-style VIN, which the first car does not have.
There is no guarantee, also, that just because a car has a US VIN style number, that it was automatically imported into the US. None of us in ~15 years of tracking these cars, has (to my knowledge; I'll have to check my detailed database at home when I get back on the 27th) seen these first 7 early cars appear in the US for sale or being owned by anyone. This leads me to think they were never imported to the US. The last two VINs are late enough that I could have them in my detailed records; I'll have to check.
Lastly, the 1,505 official MBUSA import number (which we've updated to 1,528 including European Delivery models that would definitely have been shipped to the USA under the tenets of that program) is a definitive number of models that hit US ports and were unloaded off of ships.
The nine additional cars is just speculation that they came to the USA. There is no definitive proof. Thus, in my opinion, we cannot count them as officially being brought to these shores. I believe these were US-spec test cars used in Europe and other locations around the world (perhaps including the USA) for desert + cold climate testing, etc., but not sold and used as civilian production cars on US roadways.
The primary point of my previous post was that the reliability and accuracy track record of the previous Russian VIN translation sites has been mixed/spotty, at best. Maybe this new site is good, I don't know. I haven't seen anything that says it's not. But I just prefer the data I was provided by our member, because I've met him in person, and he and his brother explained to me in detail about how they actually got the information.
Canadian cars come with the option code 460. Also Canada doesn't use miles and all those 9 cars got a speedometer in MPH. So those are definitely US-spec cars.
I'm 99% sure none of those cars were actually imported. CarFax is pretty accurate about this.
My guess is that these are all pre-production models built for various testings. The later cars are pre-production facelifted models.
Nothing is really scraped from the EPC, it is directly downloaded from the database. Yes, there are bugs in the option code translations and in the model names and there is a good reason for this.
Well, actually there is a good reason for the option code errors, but model name errors I have no idea what MB was thinking.
Anyway, here is an explanation for the option code errors.
EPC stores data in a several databases. EPC stores option codes in separate table and it's just a list of option codes with no description. Then EPC makes a query against another database which has a description of those codes. The issue here is that descriptions are tied to the date range (e.g. FROM 1995-12-31) for each code and to the type code (e.g. 210, 123, 211). Thing is, EPC doesn't have descriptions for early models and models built before 1995, this is why you a lot of times you see datacards where it says "no description is available".
Still, bad option code translations do not change the fact that those 9 cars are US-spec.
Like I said, CarFax is actually pretty accurate way to see if a car was ever imported in the US and Canada. None of those VINs have any history in those countries, so it is safe to say they were either destroyed or still somewhere at Mercedes headquarters.
What I'm saying is that these are pre-production models. Pre-production cars do end up in private hands, I don't have a specific MB example right now, but I got tons of BMW examples. Not only pre-production cars, which are finalized versions, but actual test mules end up in private hands.
I wouldn't put too much faith in the MBUSA numbers. Usually these numbers do not count press cars, show cars and pre-production cars. Again, I'm not an expert at MB production data, but I consider myself an expert at BMW production data and I've been researching it for years. Maybe I'm wrong by applying BMW experience to Mercedes, but they can't be that far off.
Like I said in my first post, those car most likely have never been imported to the US. However, it is possible that these cars still exist. When talking about production number, you should not dismiss pre-production cars.
Again, you are focusing on the option translation too much. Compare those Russian sites to the data you got, option code to option code, production date to production date. You'll see that they are identical.
I've never met the guy who provided you with the information, but I bet I can also explain in detail how they got it. I'd rather not post all of this in public, but if you want I can show you much more in a PM or over the Skype if you want.
FWIW... the 1,505 / 1,528 number was not something published from MB. That was from a list of VIN's exported from the EPC database with USA VIN format and correct country/delivery codes. I believe those numbers are 99.xx% accurate. The handful of oddball pre-production / test mules could adjust the numbers slightly, but I bet it's single digits if anything.
So far, I've found the DataMB site to be the most accurate online tool ever. Several of the older ones were really bad, the common problem was option codes missing from the datacard. The EPC would show all the option codes, but the online decoder would sometimes be missing multiple options, and could not be trusted. It was not on every VIN but it was enough that you still needed to check the EPC. Hats off to whomever got the DataMB site up, now I just hope MB doesn't try to shut it down like I assume they did with the online EPC's.
:wormhole:
It's been reported for many years in various channels (and I'd assume it originally came from MBUSA queries), that the official US number was 1,505. This long pre-dates the provision of the information by our European forum member several years ago.
I'd have to search to find a citation where it's quoted that MBUSA provided the 1,505 number, but it is definitely a number that has been around a while.
MBUSA and many other sources have also perpetuated the myth that there were only 12 E60 AMG Limited models produced. The data that we obtained, cross-referencing the two option codes for these features, showed a significant discrepancy between the "conventional wisdom" and reality.
Since we don't have any definitive information that the test mules/pre-production/early chassis US-spec models actually reached US shores, I don't think they can be officially "counted" in US import numbers.
While it is possible (and perhaps even probable in some folks' minds) that a US-spec test mule may exist in some MB or Porsche fanatic's private collection, or perhaps exists deep in a long-forgotten & sealed cave under MB's former Montvale, NJ headquarters building, there is also a very good chance that SOMEONE out of the many hundreds of owners here in the US with connections all over the country in MB and .036 circles, would have come across at least one or two of these "unicorn" early-production cars either in person or via rumour. To date, I have no knowledge of this occurring.
Mercedes-Benz Museum recently sold off a bunch of cars from their collection which had a bunch of E60s and an E500
http://alltime-stars.com/fahrzeuge/#cat0
It happens more often than you think.
Also, out of those 1528 cars, 21 cars have no history in the US and Canada whatsoever. I can PM you the list of VINs if you want so you can check them against your records if those cars appeared somewhere else.
You also seems to be still skeptical about my data. How about you test me so we are on the same page. I think a questions like "what is the 5,000th E500E?" or "what is the 1,000th US-spec E500E based on the 1,528 number" will be sufficient enough to prove that our data match.
P.S. If you are going to ask about the worldwide production data, you gonna have to tell me what we should do with the only wrong VIN in the database. Correct it or keep it the way it was ;)
I know a few VIN's which had zero records in AutoCheck. A couple of samples with nothing on AutoCheck are WDBEA36E7RC020652 and WDBEA36E6RC020657. I tried CarFax on those two and it says "zero records" as well. :?:
Wouldn't it have been possible for someone to buy the car new in USA and never register it, or have had it titled in a state that did not report the VIN to AutoCheck/CarFax back in the early 90's? I've seen AutoCheck and CarFax reports which are missing the data of original purchase/title/registration. For example WDBEA36E1NB795268 which has the first record in 1998 with 66kmi, nothing before that.
:pc1:
:pc1:
Yeah, there are many reasons why this could happen.
1. Car was never registered and is somewhere with MB
2. Car was imported for federalization process and destroyed
3. Car was exported out of the US/Canada without ever being registered
and like you said, car was registered in a non-reporting state and was either crashed or exported. It is also possible that WDBEA36E1NB795268 spent early years outside the US.
For example, like these BMWs
http://www.bmwmregistry.com/detail.php?id=8911
http://www.bmwmregistry.com/detail.php?id=11743
There are always going to be individual exceptions and anomalies - even EPC data-card data isn't failsafe, not to mention aftermarket services like CarFax and AutoCheck, etc.
Look, I didn't intend to get into any sort of pissing match, and it's a complete waste of my time to "test" anyone about the validity of their data. If you say your data is good, and that that mbdata web site is 110% accurate, that's fine. I don't need to prove my own manhood by "testing" anyone's data. Honestly, I don't spend a lot of time delving into EPC data on individual cars unless someone specifically requests it.
I have spent hundreds of hours since 2003 creating/updating/maintaining what I call my "detailed database," which is a collection of "Sports Car Market" type auction summary info, where cars come up for sale on eBay, AutoTrader, this site or anywhere else and I make personal observations about the car's modifications and condition, I record the location/colors/mileage of the vehicle, and take screen shots of the auction or other web page where the car is advertised. At times, folks who have viewed cars (considering buying them) have provided me with additional photos or detailed written reports that I add to the car's record. Many times, the car will come up for sale repeatedly over a period of years, and I try to update the car's record each time it does. I don't use EPC data for these records; rather just the car's chassis/VIN number. If it's an E60 or a Limited I notate that as well.
Over the past 5 years or so, folks here have been "recording" cars that come up for sale in the "Cars for Sale" section, and individual cars can be searched for on this site via the search box. There's no dearth of commentary and critique on this site of cars that come up for sale, so I have been updating my personal database less and less because the burden of all of this recordkeeping has been shouldered more and more on the cars' threads on this site.
It's a hobby, and I don't take things (nor myself) too seriously on this stuff. If your data is good, and you're 100% confident in it, then more power to ya!! You'll instantly rise to the top echelon of folks on this site. Sounds like that is already happening.
:pc1:
also wouldn't it be possible that when originally registered someone doing the paperwork at dmv transposed a digit or put in a wrong digit? If it was never corrected it could just keep getting passed forward. I had a 1970 oldsmobile that had a wrong vin digit on the dmv registration. Then the car could be out there but if you searched on the correct vin nothing would ever come up. Very easy to mistake a Z for a 2...etc.
Zomb,
This happens more than you think. My G320 (G-wagen) is a 1995 model, but the production date when it left the factory in Graz was in late 1994. Thus, when the vehicle was imported into the US/California in 2001, it was marked as a 1994 model rather than 1995. Which is fine with me, because in the eyes of the state, it becomes emissions-exempt a year earlier.
I also saw this with my 1989 560SEC. Although registered correctly as a 1989 model, the door plate indicates it was manufactured in calendar year 1988. And the state of Texas emissions inspector saw this on the plate, and exempted me from emissions testing forever when the car was actually only 24 years old (a year early).
Bottom line is that yes, mistakes are sometimes innocently made at the time of import or when an initial record is being made at a DMV or insurance situation, and this can be carried forward and very difficult to shake for the life of the vehicle.
There is no lack of permutations as to why and how data about an individual vehicle can be inaccurate. Probably hundreds of reasons how something could crop up being inaccurate. Which is why there is "no such thing" as one single source of information being "Gospel".
Heck, I just saw a statistic earlier this week that said that 20%+ of all Americans have inaccuracies on their credit report with at least one of the three major credit bureaus. That's many millions of Americans with inaccurate financial-related data out there about themselves.
If so much Equifax/TRW/TransUnion data can be bad, can't a certain amount of AutoCheck/CarFax/MBEPC data be bad too? :detective:
I think you misunderstood why I was asking you to test my data. It is not about some pissing match, but I just wanted to prove that I'm not pulling the data out of my own ass and the original source of your data and mine is the same.
And you are correct, EPC data is not 100%. There are many bugs in it. Fortunately, E500E data has very few of them.
For example, this is obviously an incorrect VIN. It should be WDB1240361B649251
There is also this type of a bug where US VIN is missing WDB and for some reason a random digit added at the end.
I still haven't figure out what these are all about
I'm not even talking about the model name bug or missing color and interior codes.
I'm aware that you keep a database of the "spotted" E500E which is why I asked you to check that Canadian-spec car that was ordered in the US. However, the whole point of our discussion is the data from the EPC and
Again, I'm sorry if it came off like I'm swinging my dick here, my intentions were quite the opposite.
This is also a hobby of mine, but my main focus is on BMW. Only recently I got back to all this Mercedes data and started going through it. So yeah, I definitely do not have all the answers.
P.S. If any of you crossed to the dark side and own a BMW, I can provide stats for you :agree:
Yes, wrong VIN is a possibility too. I know of a BMW M3 that has 2 VINs, Euro VIN and SAE compliant VIN. CarFax reports history under both VINs. Some reports go under one VIN, some reports go under another. So yes, that is a good point that I forgot to mention.
Zomb,
glad those mistakes worked out in your favor!
Even when you find a mistake sometimes it's not even worth the hassle to correct. I didn't bother on my 442 and the buyer knew it was a typo and also didn't want to go thru the sometimes never ending rabbit hole that is the dmv zone.
Zomb,
Actually, I think I can explain both of these.
In the case of your G-class it is pretty simple. It's a grey market car and it does not have a model year encoded in the VIN. So when it was imported into the US DMV had to go by some date. Usually they check the registration documents and use the date. However, most European document use date of the first registration and that can be years after the production date.
In the case of your 560SEC it all depends on how the emission regulations are written. Because model year and production dates are two very different things. If the regulation mention build date, then the emission inspector was correct. If it uses model year, then he indeed make a mistake.
Is it possible that MB brought several cars over for testing on US roads and conditions that were never registered? It is very common with US made cars that they take a handful out for testing. I remember seeing about a dozen Pontiac Solstice out at the Maryhill Museum one day way before the car was released. I just happened to be there that day and spoke to one of the engineers. I had read about the model and was anxious to see one in person, so I was amazed that this fleet showed up at the Museum while I was there. I have a bunch of pictures stuck away on a flash drive somewhere. I also recall seeing a fleet of Chevy HHR's near Sedona, AZ before they hit the market.
MB could have very well destroyed them or stuck a few away somewhere, as Gerry mentioned. Maybe they went back to the other side of the pond after testing.
It is an interesting topic.
Indeed it is likely that a few models were used on both sides of the pond for testing purposes. MB does a lot of testing of vehicles in extreme climates and situations. When I am in Germany it is extremely common to see MB, BMW & other marque test cars driving around, disguised. If you hang around MB HQ in Untertürkheim enough, you'll see test mules that are 2-3 years ahead of release driving around.
The A92 autobahn between Munich and Deggendorf, Germany, which passes right by the primary 3-series BMW factory at Dingolfing, is NOTORIOUS for late-night, extreme speed testing of BMW models because this autobahn is fairly straight, flat and doesn't carry too much traffic (and per German law, no trucks at night).
I've also seen MB models doing extreme load and altitude testing in the Dolomites, on the Stelvio Pass, etc. indeed, testing in the Arizona and New Mexico desert is also extremely common here in the US.
Possible that pre-production and test cars COULD find their way into private hands, but from what I know MB is pretty possessive about these things and keeps tight control on them, and generally disposes of (crushes) them without letting them get into private hands.
Which is likely why none of these early US-spec 500Es have never surfaced nor likely were registered for use on US roads.
When I lived in Denver, Mercedes did altitude testing as Mt. Evans is the highest paved road going to 14,285ft and getting to Vail goes over 3 mountain passes and about 10,300 net vertical feet of ascent -- good for testing low oxygen - fuel mixtures.
It was funny to roll up with my W163 on a W220 test vehicle which was all black, debadged, and had tinted windows. Because of my vantage point, I could see there was no rear seat bench, an awful fitting dash, and the front passenger had a laptop with a lot of cables coming off of it.
I knew what they were doing but others didn't seem to notice (or care).
Coincidentally, Porsche uses the same area as I came up on 3 black Cayennes in Boulder before it was launched.
Robert
Robert
I see a quite a few Freightliner trucks with what could be described a zebra vinyl wrap in and around the Portland area. They also just built a new test track facility in Madras, Oregon which I prepared the masterplan and land use application for Daimler only to be underbid for the final design.
I would not be surprised if some of these cars turned out to be test cars, however a yellow W124 would be difficult to hide unless it was wrapped in camo.
E500 non-4MATIC wagons. All of them got a CarFax history
http://www.datamb.com/vin/7rjKDXd4e4gEpN38B
http://www.datamb.com/vin/a987L0Elaxy2N1Kkp
http://www.datamb.com/vin/BMm8YVdBwrrEJaKyD
So I was digging around the buildsheets and it seems like Sun Yellow is some kind of a test-car color. Only early cars are painted in it and a lot of them are US spec. For a second there I thought maybe the following color is the Sun Yellow
but it looks nothing like the real Sun Yellow and it is pretty clear that these cars are just oversprayed without much care and not a factory color.
Oh I thought they were prototype 124 E500 wagons that somehow fell into civilian hands.....
A few years back I spoke with a guy who purchased a yellow 500e and provided the VIN, it came back with a yellow color via the datacard and the paint code was one that Mercedes never used in the past. The owner provided some pictures, it was a light yellow and wasn't a repaint. It is a one of one car. Unfortunately, I can't find my data on that car or the pictures.
Well, lets not get too crazy :) But I hope you can agree that those are examples not only of pre-production cars, but of models that never went for sale in the US.
As for some one-offs. I wouldn't be surprised if those exist. BMW lets them go, so I can image same things happen at Mercedes.
Here is an example of one the crazier prototype that ended up in private hands. http://www.bmwmregistry.com/detail.php?id=14855
It's a 325i with M3 convertible body and all wheel drive. BMW never built all wheel drive convertibles and M3 body was never used on a non-M3 car. The VIN number on it also clearly indicates that it is a prototype vehicle.
You are probably talking about this car
http://www.datamb.com/vin/oaz1nGEyOnOAxv67l
