I'd like to think I'm nearing the end of my 9-month-long thrash on the ol' 400E, most of which is captured in this thread. New fuel pumps are in and I just finished up replacing the rubber fuel lines from the tank to the pump and between pumps, as well as the tank vent valve. The stumble below 2000rpm seems to be fixed now, at least on my last test drives it didn't happen at all. So, yay!
The final remaining issue (until the next one appears) is an abnormally high idle. When first started, it idles around 1100 in P/N, but once fully warm, it's more like 1600. It is rock solid, just way too high. As far as I can tell the throttle linkage is adjusted correctly in that the throttle plate is fully closed when there's no pressure on the gas pedal, and there's no slack in the cable either, but maybe I'm missing something here. I'm also confused on the presence (or lack thereof) of an idle control valve. I was under the impression the ETA was handling those duties, but the AutohausAZ site shows a part number 000141242581, Idle Air/Speed Control Valve, shown for the E500, 500SL, E420, 400E, 500E. Mercedes dealer sites show same. I don't see how I would have missed seeing an idle valve while I was doing all the harness and ETA stuff, and a cursory check under the air box 5 min ago didn't show me anything I'd missed. So I'm confused on that.
I pulled the codes and pin 7 (cruise/idle control) had DTC 6, "starter lock-out / backup lamp switch" which I believe is the neutral safety switch. No codes on pin 4 (FI) and pin 17 (EZL) showed DTC 8, "transmission overload switch does not close". I did not clear the codes and then drive it for ~30 min before I pulled those codes, so it's possible those are red herrings. I think the starter lock-out one is real because that seems to always come back.
So, any suggestions?
