I’m looking for some advice regarding my W124 500E. The transmission (722.3) was replaced about 5 years ago. Recently, the shifting quality has significantly deteriorated—it’s no longer as smooth as it used to be.
The Symptoms:
1. Rough Shifting: The gear changes feel "off" (not as crisp or smooth as expected).
2. Reverse Gear Issue: The most concerning part is that when I shift into Reverse (R), the engine starts running very strangely/rough. It feels like the idle drops or the engine is struggling under heavy load.
What has been done so far:
I have already addressed the "usual suspects" to rule them out, but the problem persists:
• New Motor Mounts: Just replaced.
• New Engine Wiring Harness (MKB): Recently replaced.
Since the mounts and the harness are brand new, I’m leaning towards a transmission-related or vacuum issue. Could this be a failing vacuum modulator or perhaps a leak in the vacuum lines? Or is it possible that the B3 piston/clutch pack is causing this specific behavior in Reverse?
Also, what is the community consensus on ATF change intervals for the 500E, considering the high heat soak from the M119 V8?
The Symptoms:
