From what I've read of the discussions, everyone has this thing pretty much figured out. Here's some of the important things to remember:
When theorizing or experimenting with these things, think of their usage as designed. For example, it's easy to think of the engine braking "locked in first gear / "B" position" function as being achieved by the electrical switch in the shift gate energizing the kickdown solenoid. With a little further thought we remember that this is not true, and that "B position" is actually achieved by energizing of the kickdown solenoid
combined with the shift range selector valve in position 2.
Similarly, it is easy to think of kickdown shifts and kickdown upshift points as being achieved by the energizing of the kickdown solenoid, and this is not true. The kickdown condition is achieved by application of the kickdown solenoid
combined with full throttle positioning of the control pressure valve via the cable from the throttle linkage.
While the previous parts of this discussion may seem elementary, my experience has been that we frequently confuse ourselves by not thinking of these individual elements
within the larger environment in which they actually function.
An example of this was seen recently as we discussed our way through a diagnosis process on Oakland's transmission. If you don't remember, the problem was that his transmission shifted particularly late. That is to say it required to high a vehicle speed to produce a given shift, and when it finally did shift, it did so in a somewhat bizarre manner. Some of us theorized that the kickdown solenoid was improperly being engaged (powered) at low throttle loads. Others theorized that this was not likely because the transmission did in fact upshift. They were thinking that energizing of the kickdown solenoid alone would prevent
any upshifting. This thinking did not allow for the consideration of what could possibly happen when the solenoid is engaged but the control pressure is relatively low, as would be the case in this failure scenario. When thinking of these things singly, it's easy to imagine that that kickdown solenoid has full authority over the upshift points. It is most especially easy to think this when one knows that in a properly functioning system the kickdown upshift points are realized by an electronic control element briefly disconnecting the power from the kickdown solenoid.
The problem with Oakland's car did turn out to be a stuck kickdown switch apparently.
Here's why I went through this: We've had a little controversy as to precisely how much influence this full throttle control pressure adjustment screw could have on kickdown shifts, and indeed if it had any influence on kickdown up shifts at all. In strict theory with a perfectly adjusted system it does
not affect the kickdown
upshift points. In reality on the street, it sometimes affects them dramatically. Here's how: it turns out, and this is easily verified by experimentation with this screw, that the kickdown function hydraulics via the solenoid are actually a relatively small influence. Far and away the major influencing parameter on the full throttle upshift and downshift points whether under kickdown or not is the full throttle control pressure. As far as the actual transmission behavior goes, the solenoid hydraulics are more or less frosting on the control pressure cake. If the full throttle control pressure is too high the engine will run into the rev limiter even though the power had been disconnected from the kickdown solenoid by the electronic controls at the correct engine speed. Similarly, if the full throttle control pressure is adjusted too low the kickdown solenoid influence is not enough to raise the upshift point high enough that the electronic control element ever intervenes. The transmission will simply upshift with the kickdown solenoid engaged. I have encountered each of these conditions in the field a number of times.
So this is why one can be "correct" in thinking that this adjustment has no influence on kickdown upshift points. In a perfectly functioning and correctly adjusted system, it doesn't. However, the way the system actually functions with the kickdown solenoid controlled hydraulics being a much smaller relative influence than the full throttle control pressure, one can see why Mercedes states that this full throttle control pressure is a potential influence on
all shifts occurring at full throttle, whether under kickdown or not.
Note also that not every shift valve in the valve body is influenced in exactly the same relative degree by these pressures. It is not uncommon for example to find a valve body adjusted in such a manner that the 1-2 upshift under kickdown occurs some degree
below the electronically controlled power interruption to the solenoid, while the other two up shifts occur at the moment of power interruption. This is a measure against bumping into the rev limiter on the 1-2 upshift under unfavorable conditions. And no, that particular little tidbit is not published anywhere to my knowledge.
Eric, since you asked, there is training literature stating that one full turn of the screw equals approximately a 10 km/h deviation in the full throttle upshift point. Note that one turns the screw in a counterintuitive direction: clockwise will result in upshifts occurring at lower speeds, while counterclockwise results in higher speed up shifts.
Note something else that we have not discussed, yet that can be as important as anything else when trying to get good shift feel and high performance. The same adjustment that gives you higher speed upshift points also gives you downshifts occurring at lower speeds and sometimes with less depression of the gas pedal. It's not uncommon to tweak this adjustment higher for example, and find an a nice tasty two gear down shift in the same conditions where you only got single gear downshift before. Or you may find that you get a downshift of one gear and a more immediate vehicle response where in the same condition before you only got a downshift by depressing all the way down through the kickdown switch. Both adjustment effects are NICE!!
Very handy this little adjustment. The only downside is that you have to take the pan off. The other is that you probably will over do it the first time or two you try it...
