Sometimes while driving or when moving the 400E into a parking spot, the brake pad lining light and oil level light will flicker or stay on solid especially when I am at idle or at park. When I press down on the brake pedal, both lights will go away. The engine oil level is good (between min and max) and I think the front brakes are getting close to minimum spec but if the pad sensor did touch the rotor, won't the light just stay on and not flicker or go away?
Here's a video of the lights on. I just parked the 400E and is in Park and engine is at idle. Lights stay on solid but goes away when I press on the brake pedal.
https://www.youtube.com/watch?v=OLwEM5EGqEI&feature=youtu.be
