93 crank sensor location?
There are two. The important one is at the rear of the engine, on the driver side, at the top of the transmission bellhousing. It connects to the EZL, you can follow the wire from the EZL to the sensor.
There is also a front sensor that only goes to a diagnostic port on the fender, for connecting external test equipment. This was deleted as of 1994 USA model year and has no effect on engine operation.
:matrix:
