Hello!
First of all, I don’t have a E500, I have a 1992 W140 with the M119 engine. A barnfind that i bought for a few hundred dollars when the owner was going to send it to the scrapyard because the engine was running bad. Turned out to be the engine harness, so I made a new engine harness by my self. Drove the car for a year or so after that but sometimes it was hard to start when engine was warm. The car stood still for 5-6 years after that and now it hardly starts and the engine runs really rough, driving it is not an alternative.
Made my self a fault code reader and got 4 codes that concerns me:
Decided to tackle the Camshaft & Crankshaft sensor problems first. Ohm measurement and Voltage measurement(when cranking)on both sensors didn’t indicate any problem with the sensors, so my best guess then was a bad EZL. Replaced the EZL with a used one I bought, but it did not solve the problem. Replaced both the sensors with new ones after that, but the trouble codes stays on.
Magnets falling off the crankshaft seems unlikely but could of course be the problem with that sensor, but does anyone have any idea what could cause my ”Camshaft position sensor faulty” code on my M119???
Regards Mikael
- Camshaft position sensor faulty
- Magnets for crankshaft position sensor not recognized.
- Voltage at mass air sensor with hot wire circuit. Open or short circuit.
- Injectors open or short circuit.
Regards Mikael
Your problem sounds interesting with gsxr’s knowledgeable advise you should be back on the road soon.
