w140 s420 knock sensor
henboy1
I am getting a code that I cant reset with my blinker . code 13.That may be the cause of my sluggish acceleration but I dont seem to find the part available anywhere.Pelican and Autohauz have non.I read many threads on the discontinued part.yes, I also plan on doing the mounts while I am there
Code 13 on what pin / what module?
Knock sensor is NLA, but make sure it is bad before you bother replacing it.
Sorry , I think pin 4 . What are the ohms requirements on the knock sensor cable that I can check at the EZL ? Sluggish when completely warmed up . From reading threads here someone had the same problem and their ebay used EZL fixed it .
Check the pin and code. Pin 4, code 13 is for intake air temp sensor. Code 13 for the EZL "Not used". Something isn't adding up...
Check the pin and code. Pin 4, code 13 is for intake air temp sensor. Code 13 for the EZL Not used. Something isnt adding up...
You are right . I had 13 for the IAT sensor . I also had the knock sensor code and that was 5 on pin 17 which keeps coming back .
IAT will rarely cause any significant power loss or sluggish response. If that code keeps returning after clearing, check the connection and the IAT resistance, but I doubt it's your problem.
A bad knock sensor (or, bad EZL not recognizing a good knock sensor signal) can cause a noticeable lack of power.
Good . This assures me of the route to go when diagnosing ..I changed the EZL to another used one this morning but I haven't test drive it . If it doesn't fix it then I know my next route ....knock sensors and mount
I don't know if this will help in your search for a knock sensor, but I ordered this a few years ago, I think from PartsGeek, at the suggestion of @gsxr. I never got around to replacing it because I was planning to do the motor mounts at the same time. The mounts I replaced with BBB are still good after almost a decade.
I dont know if this will help in your search for a knock sensor, but I ordered this a few years ago, I think from PartsGeek, at the suggestion of @gsxr. I never got around to replacing it because I was planning to do the motor mounts at the same time. The mounts I replaced with BBB are still good after almost a decade.
Good to know , partsgeek have this part . Thx
I didn't check to see if they still have it.
EDIT: The EPC shows knock sensor 003 153 4428 superseded by 003 153 4728. When I check PartsGeek I'm not seeing either. Both are NLA from the dealer. Maybe the numbers on my box will help in finding one.
I didnt check to see if they still have it.
EDIT: The EPC shows knock sensor 003 153 4428 superseded by 003 153 4728. When I check PartsGeek Im not seeing either. Both are NLA from the dealer. Maybe the numbers on my box will help find one.
so, I am more likely out of luck and possibly stuck with a junkyard with the mounts.ouch
Now that you mentioned it, that would be a tough part to pull off a wrecked junkyard car because it would require loosening the motor mounts and lifting the engine to get to the sensors on each side. Maybe that’s why I don’t see any used M119 knock sensors on eBay. And I suspect @gerryvz would want at least €5000 for his.
