ETA problem
Ertech
Hi guys .
Was bored during winter and I decided to rewire my original ETA of course I damaged it .But I have 3 spares they all reacted when plugged in kind of the same way .if I use the lever very fast no problem if I went slow, it would click and go in limp mode. I just purchased a used ETA from supposedly a working car ETA is from 2005 and here is the video of the test what else could trigger lymph mode when I go full throttle with the hand it works, but when I go slowly halfway it clicks and goes into limp mode.
OK, I figured it out without tension from a throttlebody installed. The pedal switch is very difficult to keep in the on position even if you put weight on it the cable needs tension all good now thanks guys.
