Thanks to Gerry's write up and gsxr's tip: http://www.500eboard.com/forums/sho...lters-(1994-95-models)&highlight=cabin+filter
94 E500 cabin air filters (part#: 1248350047) replaced. Few questions:
(1) Saw this thin deteriorating brown foam liner/tape (with adhesive backing) inside when both filters were removed. Didn't want to breath in old foam particles and peeled it off. Photos show the brown foam liner/tape and inside area with the foam removed (There was another dark grey foam layer underneath). What is this foam liner for? Need to replace this?
(2) When I reassembled the "rain gutter" mesh back (L, driver's side), I saw a small gap (marked with red arrows in the photo). There is no gap around the mesh on the R, passenger side. This gap appears to be big enough to let pine needles and etc to go through. I noticed that both my L & R mesh pieces do NOT have any part numbers on. Also no MB "star" marks although they appear to be the originals looking at the manufactured date on the R piece (L piece has "0" markings). (photo shows the inside of the mesh) Is everything looking "normal" here? Do I have an ill-fitting aftermarket piece? Anyone has MB part#'s for these?
(3) Lastly, I can't get the rubber trim at the base of the windshield TIGHTLY back on. Windshield glass was replaced before, and I noticed that my rubber trim was somewhat "glued" to the base of the windshield. You can see the residual black glue or seal material still on the base of the windshield in the photo. So how do I get this rubber trim TIGHTLY back on the base of the windshield? Do I need to re-glue it every time? I don't see any clips here (or in Gerry's photos) that would hold to rubber trim. Trim near the center seems to stay okay, but the end portion (shown in photo) just isn't tight against the windshield glass.
Thank you in advance for your expert opinion and suggestions here.
Anyway it is weekend car so I do not worry much about it .
