WANTED ABS block non asr green sticker that fits 92 400e
Oldcar
Looking for a good tested clean block with all valves open and good seals
The same ABS unit is used on almost all 124 and 201 chassis, plus some 126 and 140 and early 129.
These are not common failures, should be a lot of used ones available pretty cheap.
:tumble:
Yes, this is an exceedingly common ABS unit. You can also find them regularly in wrecking yards, and that is probably the cheapest way to go. eBay would be another option, which provides some protection for purchase.
