Which kind of filter?
- Air?
- Oil?
- Power Steering?
- Transmission fluid?
For all of those, MB OE or a Mann filter is fine. Hengst filters are also a preferred brand, and some seem to like Bosch or Mahle filters too. I think anything that is made in the EU is going to be all right. STAY AWAY from US brands like Fram, Purolator, AC Delco, Motorcraft etc. I am also very partial to the "GUD" brand oil filters, which are made in South Africa and are a very high quality product, but near impossible to find in the US unless you're well-connected.
I try to just go OE, Hengst and Mann and I'm all good. For Hengst stuff, I have found that the cheapest prices are at Autopartswarehouse.com (buy filters there ONLY) with fast shipping, and you can also get them via Amazon.com for a bit more dough. Mann stuff is available via Autohauz and other vendors for decent prices. Or you could go through MB Asheville or Lionel for MB factory stuff.
There are no real tricks if you're talking oil filter - you remove the long bolt holding the filter canister cap on and pull the filter up and out. Do this before sucking out or draining the oil from the pan. Be sure to replace BOTH rubber o-rings on the canister cap on the M119. Also I think there's a metal washer under the bolt head that should be replaced that comes in the kit. And if you drain from the pan, a new copper drain plug washer comes with.
Air filters (yes, takes two of the rectangular jobs) you unclip the top of the air box and carefully lift out the old and install the new. Don't drop/lose the clips when you pop them. Good time to clean out the inside of the airbox with a moist rag. Do these filters every 20-30K miles. Don't need to go fancy with a K&N or whatnot ... just use Mann paper filters and you're all good.
Power steering filter .. you just drain out the fluid (you can use a turkey baster to suck it out of the reservoir if you're doing a partial change) and use a hooked tool/awl to pull the old PS filter up and out. These are often neglected, so best to do it every 3 years / 30K miles or so.
Transmission filter. The 500E and 500SL use a special filter with another outlet and a slide that moves back and forth inside the filter; I haven't looked to see if the .034 (400E/E420) uses the .036 filter or not (GSXR can confirm or deny). But....a "regular" 722.3 filter will work just fine on any M119, and it's the same trans filter that a 560SEC/SEL or any other 722.3-based car from that era uses....dozens of models!
Commonly available via Autohauz or other online vendors. Get a Mann or other name brand (the .036 specific filter I use is made by Elring, a good brand) or MB OE. Don't use a cheaper brand like Meyle. The .036 specific filter is hella expensive from MB, so the aftermarket quality Elring is a great and much cheaper alternative.
Hope this helps a bit, depending on which filter you're replacing.
Uh bro it's in the Transmission and driveline section so----.Which kind of filter?
- Air?
- Oil?
- Power Steering?
So can some one tell me if I need the E-500 spec filter for the E-420 unit??Transmission filter. The 500E and 500SL use a special filter with another outlet and a slide that moves back and forth inside the filter; I haven't looked to see if the .034 (400E/E420) uses the .036 filter or not (GSXR can confirm or deny).
I have a source for GUD stuff here in the US, but honestly Hengst is easy enough and can be had via autopartswarehouse.com cheaply (or Amazon), and is same quality.
Was surprised to see that the Klinkmeister knew of GUD. http://www.ptsfilters.co.za/p/178140/gud-filters
They all make transmission filters for the .034 and .036?Avoid all the store brands... that includes avoiding Purolator, Wix, NAPA, Bosch, and almost anything else. Yes, they are name brands, but they are almost all reboxing Chinese junk. Again, for the two bucks... just get OEM.
They rebox transmission filters. Probably Chinese. And you'll probably pay more too.They all make transmission filters for the .034 and .036?![]()
Hengst, Knecht, Mahle, and Mann are OEM and usually fine. Given the couple bucks more for OE/Genuine, most of the time I just get OE. People agonize over saving the two bucks, it isn't worth the time spent researching or discussing it.
All the old BMW filters were made in South Africa by GUD also. Like Gerry said any of the EU filters are good, but I would skip the Bosch personally. They look cheap in person.
For me it's not the $ it's that I have a choice of grabbing some thing local in a no name brand, getting raped by my particular steeler, or mail ordering and waiting. Wondered if there was a solid "off brand that would be a good choice. On this one looks like unless you are going with the 195 series HP filter it shouldn't matter much as these aren't real filters just strainers on these units. I spent some years in a Trans shop and some of the older units had real filters rather than just a box with a screen like the garden variety version of these units use.Hengst, Knecht, Mahle, and Mann are OEM and usually fine. Given the couple bucks more for OE/Genuine, most of the time I just get OE. People agonize over saving the two bucks, it isn't worth the time spent researching or discussing it.
on this change I'm going with just a generic filter like a normal MANN or some thing as I have found it is overdue on the change by about 25K. I will run this change with the Castrol Dex Merc and a normal filter to flush things out then change again in about 20K using the HP filter and Redline D-4.
Thanks for that man as from what I saw in the photos of the filters closed they looked like they had the screens only not full internal filters so that's good to know. The filter on the AW I have in my Volvo is just a strainer as are most you see today it's not common to see full filters anymore.I don't remember if anyone answered your question before, or even if I may have, but these are indeed actual filters with pleated media elements, and inferior ones do come apart.
For that matter, once you get the old filter out, go ahead and cut it open and inspect the element. If there are any kibbles or bits in the element and/or the pan, photograph them and post them up. We can probably tell you what they are...
It's been said before but it's worth saying again: Do not run your filter much past 30K miles no matter what fluid you are using.
+1. WHy I've always run traditional fluid. When I get a rebuild for my E500, I'm going to start it off from the get-go with synthetic, but my other cars will continue to run dino ATF at 25-30K OCIs/FCIs/And knowing these are full filters not strainers that now makes perfect sense thanks.
That now raises the question as to why there would be an advantage to running synthetic fluid in these?
The real advantage with running synthetic is it won't chemically break down due to heat over time and pressure like normal fluid but at only 30K change intervals a standard fluid should perform very well and not break down. I really don't see much advantage on running synthetics here over a high quality standard fluid like the Castrol with those short change intervals. Now get up around 50K or so I can see it but not at at just 30K.
That helps as I still have my my monster 3 foot long Snap On screwdriver that I used for many years as a universal pry bar so---. Knew I didn't have room to use my flywheel tool to grab the starter ring and turn it over like I did with my old big block Pontiac's.I just use a large screwdriver to lever the torque converter housing around so that the plug lines up with the opening, to drain. No big deal. You can do with a helper running a key in the ig, as well. Either/or. Screwdriver is fine though.
And this is why it is a good practice to plan well in advance for repair & maintenance jobs, so you can order OE/OEM parts and have them shipped to you, before you need to do the job. Then you are not stuck between the rock (local junk purveyors) and the hard place (local stealership). Problem solved.For me it's not the $ it's that I have a choice of grabbing some thing local in a no name brand, getting raped by my particular steeler, or mail ordering and waiting. Wondered if there was a solid "off brand that would be a good choice.
Bingo. A lot of people poo-poo synthetic lubes as a waste of money, but one of the numerous advantages is reduced fluid temps and reduced component temps.You being a transmission guy, what's the #1 enemy of an automatic gearbox?
HEAT.
NO !!!Did someone say transmission fluid ??......................![]()
If there is room and it won't over torque the balancer bolt definitely a better way to go since the old tool I have doesn't have room here to grab the starter ring! Will do on marking the balancer good tip!!Oh, hmmmmm, screwdriver hey........
I prefer to use a 1/2 breaker bar and 27mm (1"1/6) socket on the crank bolt.
Like Dave said, mark the balancer once you get the drain plug showing.
Saw the same thing in the 600hp highly modded 455 SD Pontiac I used to run. We were running Penzoil Synthetic back in the early early 1980's in that one. Had a minor issue where we needed to pull it down after 10K or so on the street and a number of 6500+ RPM passes and were stunned with how little wear we saw and how clean it was.Bingo. A lot of people poo-poo synthetic lubes as a waste of money, but one of the numerous advantages is reduced fluid temps and reduced component temps.
Interesting anecdote: In the early 1990's, I had a chance to chat with a guy who had worked on a professional race team for a 7+ figure car (IIRC, he was the engine builder, and the engine alone was well into 7 digits). At the time, I was a Mobil-1 fan and asked him what he though, i.e. was it worth the cost, or a waste of money. He said they had switched the race car to Mobil-1 as well, reduced the quantity needed for the dry-sump system from something like 25 quarts down to like 10 quarts, and it dropped oil temps around 30°F. Bottom line, they loved the stuff. And this was a competition team that could have used anything they wanted.
Thanks sounds like a plan then!No chance of that, trust me, mega torque spec on that bolt
The torque spec on the crankshaft pulley bolt requires the average home mechanic to call Superman to pay a visit to torque it for them.
The only other way for a mere mortal is to use an 8-foot breaker bar connected to your torque wrench. I think the spec is around 275 lb-ft.
No way you will loosen it just turning the motor. And be sure to turn the motor the correct direction
I find it easier just to use a screwdriver to rotate the TC, but that's just me. Or if my wife or son are around, to bump it using the key in the ig.
