CV Flange bolts torque
Black 034
Need torque value for 6 bolts holding axle to differential flanges? I have new E-torque bolts or can resuse XZN with new blue loctite.
I had similar problem when I bought febi CV boots. There were double amount of needed parts and wondered why. Didn't pay attention and send some nuts to yellow plating and when I was assembling rear subframe and mounting CV axles realized that plated nuts were too big. I was confused that how those nuts will not fit if the boots were right and it was proper kit. Then checked the rest of the nuts and they fit..
So I ended up plate wrong ones :facepalm:
I struggled with same issue and did not find any centering tabs. I don't know what will happen if my CV axles are not centered. Will see when car is ready. :detective:
Next time I will mark the sides and position properly before disassemble.
