Hi. My E500 94' start to go in Limp mode more and more often.
Then i got som tip to check some things.
First upper engine harness, this was changed in 2002, the date on label on the harness say that.
And then i check trottlevalve/trottle actuator, have been changed in 2004, date on label.
Then i should try start the cold engine, and check that the engine revs up to 11-1200rpm once it start(chocke). That do the engine not, so then my friend recomded to try with another EGAS module, and i do. Then the engine revs automatic fore a moment when it starts, and the engine runs very fine. No problem after i changed the EGASmodule.
