I've had a few situations where my 500E has been sitting for a couple of weeks. When starting it up, it struggles a bit to get up at a normal idle speed, and engine shakes. Takes about 3-5 seconds before coming to normal.
When I look in the rear mirror there's quite a bit of smoke back there. And it is blueish.. But the smoke is gone within 10 seconds.
There's a minor tikking noise from the left block (close to always); right one sounds ok. The other day I started it after sitting 4 days. Now this time I hear some light knocking.
Checked the oil cap to see if there was any paste residue from coolant leaks - but it's clean as honey. I change oil Mobil1 5W-50 Rally Formula every 6-8000 km. There is no noticable track of oil in the coolant reservoir either.
Is it really possibly to get blue smoke damping from a rock solid M119 engine?? I thought these V8 blocks were immortal :-|
It's got 226K KM on the clock.
I've heard someone talking about fuel dripping into the combustion chamber, which can be fixed by replacing gaskets at the plugs.. Please correct me.
By the way I got confirmed from a diagnosis expert today, that my upper wiring harness definitely needs replacement asap - 124 440 20 06.
Could failing oil tubes create this problem? Lean running? Failing cylinder? Blue smoke?
What to do? Hope it doesn't break down dying on me
