On and off simple Let me explain, as part of my ASR light fiasco I fitted a new brake light switch
I had been having trouble with brake lights staying on and then no brake lights at all
I bought a new switch from the dealer matched to my vin the white plunger was pulled out and moved
freely and the 2 wireing harness plugs could not be mixed and only fitted one way
When the fault codes were read the was a code for the brake light switch which was cleared we then ran the car
The man reading the codes appeared to be viewing live data on his lap top and he told me the switch was not working correctly
I was told when the brake pedal is depressed one set of contacts should be closed and the other open and when the pedal is released
this should reverse with the closed contacts now open and the open contacts closed, I can easily remove the switch and test this
but is he right ? Its a new genuine vin matched part 5 days and 3miles old The brake lights do work fine
Its my doubts over this diagnosis that makes me a bit suspect about his ETA diagnosis
So before I start pulling things apart I would like to:
Any other suggestions welcome
Graeme Johnson
- Test this brake light switch for correct operation ( how should the contacts be working )
- Fit a new contact switch to the throttle pedal (no codes but its cheap and wires could be damaged/ flexing while driving )
- And most important have a good look at the throttle linkage and the stop positions on the ETA
Graeme Johnson
