tail light electrical gremlin
natejgreene9871
1993 400e, 1984 300D Turbo, 1976 450sl, 1993 190e
I've been dealing with a tail light issue on and off for about a year now and I can't figure it out.
It is intermittent, happens about about once a month, no rhyme or reason. Goes away on its own but comes back.
On the drivers side tail light - the red running light will quit working ( blinker unaffected). i'll get the warning light on my dash.
i've tried swapping in a different tail light housing, i've also cleaned the ground cables where they all screw to the body around the antenna motor. Didn't fix it. This is a clean car, no corrosion or rust.
Last time it happened, I used a multimeter on the pins of the tail light plug and I was not getting power at the pins. So it is something upstream in the wiring.
What other body grounds am I missing here? Seems like a corroded connection I just cant find it.
I fixed it! @vanwiek was right on the money. I removed the lamp module from the fuse box and took it apart.
Upon close examination with a magnifying glass 3 or 4 of the larger solder joints had cracks in them. I reflowed all the larger joints with a soldiering iron and put it back together. East fix, took about an hour.
View attachment 202050View attachment 202051View attachment 202052View attachment 202055
I’m glad I was able to help!
So the story continues. The warning light came back again after a week, but this time it was only when the brake pedal was depressed.
I took the tail light housing apart and there was some corrosion on the contact bars. I already cleaned this up about 6 months ago but I guess it came back.
I made a slight modification, soldered some wires for redundancy. This housing isn't a great design, especially in a humid trunk.
Tail lights are a lot brighter now! No more warning light. Hopefully this will finally put this issue to rest. I think both the light housings and the module were causing issues.
