As you can tell from the photos below, my window switches on the center console are not seated properly/consistently. Also, my shift-gate ring does not sit flush with the center console. Before I go through the trouble of removing the the center console to see what the trouble is, I would like to know what others have experienced and done to remediate this problem and perhaps obtain some parts that could correct the problem(s) before I get started. I recall seeing a recent thread that discussed some of the attachment parts (clips maybe) that are used on the underside of the center console to hold everything together.
I have heard from a very reliable source that there are two different types of attachment for the wood & switches: (1) one type has the switches in a separate plastic frame, and the whole frame clips to the wood, and (2) the other type has the switches individually click into a plastic frame stapled to the wood. This second type is how the seat-heater switches are connected...they click directly into a plastic frame stapled to the wood, there is not a separate switch holder.
Does anyone happen to know which type is used on the E500E? Also, does anyone recall the recent thread that discussed this matter? Last, if anyone could point me to the part group and sub-group for this that would be great!
