Postby Powerman on Thu Apr 02, 2009 7:34 pm
Is it possible to change the GPI without removing other parts? Today when I checked it out it seemd quite tight over there...Thanks to GSXR I've managed to point out that it's toasted and has to be changed.
280E '81
500E '92
Powerman
Postby J. M. van Swaay on Fri Apr 03, 2009 2:17 am
Check this out
http://www.mercedesshop.com/Wikka/W124ShiftKnob
Yours is the same except that you have to deal with the B switch. Rik Carlson (2phast) has some good pictures of the B switch on his website where he describes his FGS install.
First time I did this it took me about 1 1/2 hours. Once you know how, it's a ten minute job.
J. M. van Swaay
Postby Powerman on Fri Apr 03, 2009 2:33 pm
The part I'm refering to is on the left side of the tranny, aka back-up light switch i think. But thanks anyway!
280E '81
500E '92
Powerman
Postby gsxr on Fri Apr 03, 2009 3:29 pm
Pretty sure when I changed mine, nothing else had to be removed, and I did it with the tranny in place. I don't think I had to lower the tranny, but for a little more room, you can un-bolt the rear transmission support and lower it an inch or two. Clearance is VERY tight though.
Dave M.
Boise, ID
1995 E420 (W.I.P.)
1994 E500 (Q-ship)
1993 300D (Sportline)
1987 300D (Sportline Stage 2)
1987 300D (R.I.P)
Postby Powerman on Fri Apr 03, 2009 7:17 pm
I think I'll need that extra room... Hope the tranny wont drop on my head.
:rotfl:
280E '81
500E '92
Powerman
Postby wpirie on Fri Apr 03, 2009 9:32 pm
Are we talking about the Neutral Safety Switch? I changed mine without removing anything else or lowering the trans. Space available to work in is tight, but not as bad as it looks. Only two bolts and the electrical connection to undo. Remember to align using a suitable diameter (4 mm?), short pin. I cut a drill bit down to about an inch and a half length to fit in there.
You do not have the required permissions to view the files attached to this post.
wpirie
Postby gsxr on Fri Apr 03, 2009 10:07 pm
Yep, that's it... neutral safety (aka starter lockout), backup light, and gear position indicator, all in one multi-function switch. I used a piece of electrical wire with thick insulation that happened to be around 4mm, that worked great... I was able to make an "L" shape to more easily fit into the cramped space.
Postby J. M. van Swaay on Fri Apr 03, 2009 10:14 pm
DOH...............what was I thinking. PRND21...........
J. M. van Swaay
280E '81
500E '92
Powerman
Check this out
J. M. van Swaay
280E '81
500E '92
Powerman
Dave M.
Boise, ID
1995 E420 (W.I.P.)
1994 E500 (Q-ship)
1987 300D (R.I.P)
:rotfl:280E '81
500E '92
Powerman
wpirie
J. M. van Swaay
