Hub is NLA, if damaged beyond repair you'll need to source a new one.
How is this "stripped"? There's no threads. It's a press fit onto the crank snout. A puller is needed to remove, installation requires heating per FSM spec so it slides into place.
This applies to M119 engines with the 2-piece hub/balancer through, IIRC, early 1995 model year production. Late style 1-piece is a slip-fit, completely different.
