Crankcase Breather filter
cm60k
Anyone got idea why we don’t have Crankcase breather filter,,??, and someone confirm to me, is that hose located in the Right Valve
cover (119 094 78/79/80 82), for the Crankcase breather.....???
ZAYED,,
I have a filter there in the right cylinder-bank between 3rd and 4th cylinder. Its "inside" the engine, means at the top of the cylinder-head below the valve-cover.
Thats very good Chris., what kind of filter you using.? and is it with 1 or 2 pipe lines..?? can you post some pics..........
ZAYED,,
Well thats all stock.... I hope we mean the same... let me check my EPC...
Parts marked. Its a small filter/sieve kind of thingy, it is called "oil separator/oil trap" in the EPC.
The metal-hose which is hard-connected to the right valve-cover is placed inside of it when you install the valve-cover correctly.
Woooo, i didn’t know that, Thankss alot, i think i should open the Valve cover and check that, but its soo small, why MB not make it a
little bigger & put it above the Valve cover not inside, thats makes easy to change it & avoid that hell temp. inside the Engine.....!!?!!
ZAYED,,
When i open an oil cap lot of smoking air escaping,, maybe the Crank breather filter is closed with a greasy oil or somthing(just
thought),,
ZAYED,
