Hello,
I've gotten in contact with aFe in regards to their M119 product offerings:
I saw that they had a "performance" air filter for our engine, but only had the Pro 5R model, which is an oiled filter.
Traditionally, aFe have always had two drop-in options (well, three if you count the "off-road" one), one that is oiled (Pro 5R), and another that is dry (Pro DRY S).
In my observation, many enthusiasts have no idea which air filter option is the best, and there is a lot of misinformation on various forums, not specific to any car model.
Like anything without extensive test results, there are mixed opinions on the topic and people that will swear on it, as well as people that will swear against it.
My own informed conclusion from reading is as follows:
With that all said: A performance air filter, or any air filter for that matter, should have a very trivial and almost insignificant effect on performance, but as enthusiasts, it's always intriguing and enjoyable to figure out what gives us that extra 1%. It's really important to remember this may be a subtle change, and might not be worth the costs at all for what improvements there may be.
To the point:
I've shot aFe an email a while back, and noticed that they added the Pro DRY S filter for our M119 engine to their shop! (Hurray!)
Disclaimer: I'm not affiliated, just another enthusiast that cares about our cars and wanted to share this with the community.
Here's a link for it:
http://afepower.com/afe-power-31-10125-magnum-flow-pro-dry-s-air-filter
The little marketing blurb they have:
"Constructed with 100% polyurethane on all four sides, this high flow "oil-free" OE replacement performance filter will outflow stock paper filter for improved horsepower and torque. Two layers of progressively finer mesh synthetic media provide maximum convenience and easy maintenance. Washable and reusable for multiple cleaning cycles, the tall open evenly spaced pleats provide excellent dust holding capacity for longer service cycle between cleanings. Integrated urethane bump seal insures tight, no leak seal over the life of the filter."
I would love to hear some thoughts on using these on our cars. Perhaps someone might have a strong opinion on using the factory paper filter, or have actual experiences with aFe's Pro DRY S filters.
-Kevin
- OEM paper air filters filter well, are the safest option, and are easy to R&R at the specified service intervals - just have to throw away the old one.
- Oiled aftermarket performance air filters (K&N makes the most I believe, aFe makes them too) are bad news. It is more difficult to service/wash and re-oil the filter, often resulting in too much oil on the filter. Regardless of over-oiling the filter or not, there are plenty of examples of MAF sensors going bad (on various makes and models), due to the oil from these filters reaching it. I'm not a mechanic, so I don't know the specific reasons, and whether or not the M119 is affected by this, but I'd rather not risk oil entering the car from the intake. Pros are re-usability, but you'll have some people drop them in and forget about them.
- DRY aftermarket performance air filters, the only risk I see in this is whether it filters as well as the OEM paper ones or not (letting in too much dirt/debris, harmful towards the engine) - I do not know. If it filters out dust/debris as well as the OEM paper ones, but allow a bit more airflow, I see it as a potentially better option than the OEM paper ones, as long as you don't mind having to service them by doing three things as per the factory recommendations (1. turning them upside down and tapping, 2. vacuuming it afterwards, 3. soaking it in light soap solution and letting dry after). This is the one I'm interested in, as I see potential in it.
To the point:
-Kevin
