m119 misfire still there after the distributor changed
You are going to remove the valve cover and replace seal (do both sides why not) and the oil separator. May want to review guides and tensioner while you are there. torque specs matter on them, but I bet GSXR will have another thought or two on this, that is not a happy look - arcs.
That's a healthy spark... in the wrong place!
Hard to tell what the root cause is without more information. Looks like new (non-resistor) plugs gapped to 1mm are in order, along with a set of plug wires.
If there is liquid oil pooling at the base of the plugs, the valve cover gasket may be leaking - in which case you'll need to replace those too. A small amount of oil residue on the threads is normal.
:run:
whole plug was lubed in oil lol
Hi everyone. I've been registered on this forum for a while and I'm not sure whether I should start a new thread or not. So I'm starting here first.
Two months ago, my 400E w124 wouldn't start after a short stop. It only started after a few attempts. No power and misfiring. I just barely got home. Then I noticed that the distributor caps were quite wet on the inside. So I ordered and installed new caps, distributor rotors (both Bosch) and new camshaft seals. Sparkplugs new. Now the engine starts again, runs good, but when it warms up, the misfiring starts again. The engine wiring harness has been new since last year. I installed new ignition coils today (Bosch). The problem is still there. While idling, I disconnected the hose from the fuel pressure regulator. No gasoline is coming out, so it's fine i think. Driving with the air flow sensor unplugged made no difference. So? What next? Ignition cable? Oh, no errors stored in the error log.
And at least, sorry for my english. I tryed to translate as good as i can 🙈
Sounds like you need to add the additional vent slots to your new caps, AND also eliminate all oil leakage from the exhaust cam seal & intake cam advance magnet/solenoid. Read this thread for details. Very likely this will cure your problem.
:shocking:
Hi. Before i installed the new caps i add the vent slots. I will reinstall the old distributor caps and rotors as a test to see if the problem persists. Even new Bosch parts have reportedly been defective in the past. So let's get to work right away. More information to follow later today. An introduction thread will also be posted in the coming days 😉
Jesus man... i cleaned up the old rotors und caps and just installed them. The isolation are the new ones. What should i say... it runs fine. The new Bosch parts are bad out of the box... production date 05/18 😐. Im happy that it runs fine now... but, i mean, what a joke... should i install the vent slots in the old caps? What do you think? Behind the Isolation caps its dry like the Sahara dessert.
You should still modify the caps with extra slots and go deep on the ones in the bottom even slightly into the outer flimsy plastic.
Yes some of these components are crap out of the box. One thought here is to add the wd40 wipe on everything, including the aluminum housing that we connect up to. In a hot environment, moisture will appear with the humidity (out a cold soda/bear can outside in the summer, use the shade if you want but the can will sweat!) and if there isn't the ability for the atmosphere inside the cap/insulator/rotor and the aluminum and oil vapors along with the other gasses created to adequately escape then you got the funk. New stock by Bosch is showing up with deeper and extra slots out of the box.
Aaaargh! Sorry to hear that. I once had a defective new Bosch cap out of the box, but it "only" caused a misfire on 1 cylinder at hot idle. Sounds like yours is worse. On the bright side, you identified the root cause and fixed the problem. For now, yes, add the vent slots in the old caps. See if you can return/exchange the new Bosch caps.
:tumble:
Hi 500E forum
Its been a min since i gave a update i have gotten my 420e detailed cleaned up and as for the car overall its is not running i have changed the MAF sensor which is from a 97 s500 w140 the updated one ill upload a pic down here also i havent changed the coil packs and the ezl what should i change first and what are good adivce on sparkplug wires one more thing what all systems work with ignation to spark plug.
Thank you again
Hi e500 board good news i found a ezl that will maybe come on saturday a local 500e owner reached out and said i have one so he is giving it to me for testing if my car works i will buy it but i want to know if it will work cuz my ezl number is different.
ps the one dusty is mine the other is his
WhatsApp Image 2025-12-03 at 22.34.46_1e93e898.jpgWhatsApp Image 2025-12-03 at 22.34.46_41e93b70.jpg
Although you can use any V8 LH module interchangeably, the same does not apply to all EZL's. Certain EZL+engine combinations will NOT work. I am not sure if the early 5.0L EZL will work with your late 4.2L engine. From memory, when I had tested this in the past, the engine either will do weird stuff at idle and/or throw a bunch of fault codes. You really need to test with the correct part number EZL for the car. However, if all 8 cylinders are firing, it's unlikely your EZL is defective.
can i use pc thermal paste on it ?
Yes, but don't bother installing the spare EZL with thermal paste. Lay it on top of your old one, the wires will reach for test purposes.
Hi 500E forum
The MAF from a 1997 with ME injection is a different design than the 1992-1995 MAF for LH-SFI injection. The later MAF will not work properly.
:runexe:
Hi its been a while been gone for uni now back for this nightmare :cel:
So the car isnt still working and now it doesnt want to start i want hear quick check list of things ill have to do here is so far i have done and not done.
distribtuer caps changed
distributer rotors not changed
coil packs not changed
ezl not changed
maf sensor used a w140 which didnt work switched back the w124 maf no luck :(
spark plugs all changed gapped to 1mm
insulator caps not changed
maf rubber boot changed
some vacuum hoses for the ezl changed
throttle body not changed
spark plug wire not changed
also any advice on where to find these parts
thank you again for the support over the years and forgiving me of my stupidity
If it won't start at all, first try squirting some starting fluid down the MAF. If it STILL won't start, that means you have no spark on any cylinder. Most likely cause is a failed EZL but a dead crank sensor (CKP) could also cause a no-start condition.
If the engine fires on the starting fluid, you have a fuel supply issue.
well i feel like dumb i just checked and i dont got gas while im down there i found out im running with e320 fuel pumps and the filter is clogged up here is a pics
Fuel pumps are the same on most all 124's (except late 1995 builds which use a single pump). But yep, need gas in the tank and a clean filter! Make sure the pumps run when the key is turned on. The pumps should run for 2 seconds every time the key is cycled.
:tumble:
hmmmm that is working the fuel pumps but i hear only one tho
Make sure both pumps are working. The car will not have normal power with only 1 pump running. If you need to replace the pumps, use OEM Bosch only and replace both at the same time. Part numbers are in this thread.
So i got the car to run i put new fuel filter and some gas and starting fuild it ran but rough and was running really rich also i disconnected the maf sensor than it ran before i tired didnt ran so thats wha i had to do ill send a clip of it running and is it possible to rebuild the maf and spark plug wires ? the injecters need a rebuild i found a guy who can do it for 120bucks with new seals here are the clips.
Can't rebuild the MAF. They are relatively rare failures, don't replace it unless you know for certain it is defective.
Rough running = misfire. Is that a visible spark I see at cylinder #5? If so - you need to replace the wire set. The factory wires can be "rebuilt" but the cost is high, and you need a special crimp tool that nobody has. Best option is to get the Beru wire set shown here if you need new wires.
Injectors cannot be "rebuilt", only cleaned. $120 is a good deal if that includes flow testing and new O-rings / pintle caps. More info here.
I took out the spark plug wires today to check there condition it was pretty fair but bad the one that was doing disco dance with electricity got taken out meaning it broke and one that was socked in somthing as i can out Resident Evil type of thing only in one cyl. they look like oem spark plug wires overall never been changed. any here is video of me in pure pain
FYI - none of the factory Mercedes M119 ignition components are made by Bremi.
OE/OEM are Bosch, Beru, and Doduco only.
Several of your plug boots have part of the plastic broken off as well. That entire wire set needs to be replaced.
:strawberry:
All right so regarding for the spark plugs I ran a test so what I did was I had some spare 1K ohm resistance spark plug cables only two piece and I know the spec for the m119 2k ohms and it little rough as usual so I'm posting this video let me know what I should do next cuz I was boggling down and at one point I couldn't use the throttle then I just restarted and it started working itself like self calibration or something i dont know
