During the process of removing and installing my crossover pipe, I loosened the two 13mm nuts where the front exhaust pipe connects to the transmission along the frame rail (diagram). I noticed the whole bracket mounted to the transmission seemed to creep forward because I had difficulty getting the two bolts back in afterwards.
Now, I noticed that the crossover pipe is rattling against the front of the transmission pan. It's actually the outer part of the crossover pipe, but it's making an occasional rattling noise when I come to a stop. I'm sure this is not good.
As you can see from the picture, I wedged a piece of fireproof hose in between the pipe and the pan.
Does anyone know how to get the transmission to move back just 1/4" so there is clearance between the pan and the crossover pipe?
