Crush washer help
EDMB500
Guys I’m fixing to do the camshaft oiler tubes and reading Gerrys how to guide it mentions new crush washers N007603006106. I can’t find these for the life of me on any stockist or eBay. Can someone please point me in the appropriate direction? Must these be genuine MB or is there a suitable alternative? What are the dimensions of these?
appreciate the support, thanks
Remove the "N" before the number and you will find far more results. Most part catalogs / vendors will turn up zero results searching for N007603006106, but should work fine searching for 007603006106.
Guys thank you. I have no idea why the autohausaz search will not work for me. I used the number without the N and also without a hyphen in the middle of the number, didn’t know there should be one, and it says nothing found. So I’ve used your links. Very strange.
