Just curious to see if anyone cares to share how they replaced their drag link WITHOUT the MB tool. I do have a replacement as the movement is a bit sloppy IMO. So interested in a picture of the tool used to separate the unit from the attachment points.
I use the Klann shown below. It is designed for the tie rod ends, not the drag link joints. With the engine installed, there is just barely enough room to fit this tool in place on the drag links, and even then it often needs heat applied to the idler arm or Pitman arm before they pop free. I'd like to buy the factory drag link tool but the price new is out of my budget, and I've not been able to locate a used one for sale.
YES - definitely need to do this with aftermarket tools. Clearance is tight on the top side of the drag link joints. With the engine removed there's plenty of space.
