W124 Rear Sway bar A.K.A. ''ARB'' Links and bushings Torque Spec
Merso_AMG
Hello.
Can anyone confirm what are the right torque specifications to the W124/210 Rear Sway bar links and Bushings?
On the images you can see, what about i am asking.
Merso AMG: According to the FSM ( 32-310 ) sway bar bracket to chassis floor is 20NM and vertical link to sway bar is 30NM. This is for a W124.036.
Regards,
Peter Weissman
geraniumtr
Because W124 and W210 share the same sway bar links: 1243200289 and the bushings itself look very similar: 2013261581, 124 326 05 81
i think that this specs will also work with W210.
Thank you very much!
