Moderator edit: Cleaved these posts off this thread discussing aftermarket front control arms.
Got the dealership on the horn and some of the prices are competitive between them and online, and other ones are not. If I go to let's say Pelican or Autohaus and see "Mercedes" Brand and then right under it "Lemfoerder OE" brand at a cheaper price, what really is the difference? Can I go Lemfoerder on everything? Or should I go Mercedes on everything, or are they one in the same and the Mercedes is just marked up?
Tried to do a search but didn't really find anything. I'm looking at doing all the rear arms on my vehicle. camber, pull/torque, tie rod, push/thrust, control/spring arm.The early LCA will not fit cars that need late LCA's (like your E420), unless you grind a few mm off the end for clearance to the brake disc & shield...
