V12 rear brake upgrade
Quick4door
I found an SL 600 in the local pick and pull yard last year so I grabbed a few things off of it, including the rear calipers. I already have the silver arrow front brake setup (60k on it and works great) Per the W124 break table, these were unique to the V 12, being 300 x 22 mm instead of my stock 278 x 24. Backing plates are the same, everything should bolt right on. Picked up the vented and cross drilled rotors Pic for reference between the v12 and stock 034/036 stock rear setup. Will post a follow up as soon as the rotors get here!
