My driver door lock key will not turn counterclockwise, but with lock assembly removed from the car the key turns both directions completely. I have the latch assembly out of the door and I can't get the white bushing to move more than a few degrees. Do the latches go bad often? Everything else works fine opening with either outside or inside handle. The plastic bushing the lock assembly is undamaged and everything lubricated.
