WANTED Euro Headlight Leveling Kit
outrbnks
I've seen pictures of the Euro level dial next to the light switch on Euro cars.
On google I've come across what appears to be a retro kit, (picture attached).
does anyone know if this is a kit and what the part number might be?
There is no kit from the factory, you have to buy all the individual parts. Someone may sell a kit with everything but it will likely cost more than buying the pieces separately.
That said... I believe the correct trim bezel with Z-shaped cutout for the steering column escutcheon is NLA, but you can get the type shown in that photo and use a Dremel to add the appropriate "Z". Also, that photo shows the older setup; the period-correct E500E level adjust uses a dial with 3 ports, nifty purple tubes, etc.
Photos here:
http://www.w124performance.com/images/W124_headlights/level_adjust/
:tigger:
I installed the adjustable gig on my C126. It is a kool feature, but hardly a chick magnet. I'd opt for new Intake Tubes instead, Just Sayin!
