The MB 8 hole 16 X 7.0 ET 46 is a good alternative.
Used on Euro 400E with
215-55-16 tire
It's on the EPC under Euro market
Absolutely, Vader!!
I have experimented with just about every non-silly tire and wheel combination possible using factory wheels on 124's and this set up is absolutely the ultimate for a non E5E, IMO.
For those that didn't know, just as on early 500E's, the first version 400E brakes just weren't big enough to avoid complaints in Europe. In a manner and time frame virtually identical to the 500, the remedy was to convert them to the then current production SL600 front brakes as of early '93 production. That change required this particular 16" wheel. At around the same time the WIS listed this wheel as an approved accessory for most 124's. This brake and wheel modification was not done on USA version cars in the interest of CAFE.
I realize this next part won't be considered a benefit by everybody, but it is an enormous plus according to my personal taste. That aesthetic benefit for me is that with this set up the car looks absolutely dead stock, except somehow exceptionally good.
The functional benefit which is vastly more important is that this setup actually works! It is straight "bolt on" as there are no clearance or modification issues of any kind. It rides correctly, steers correctly, has a linear response and breakaway. It doesn't stimulate annoying resonances and vibrations. It looks and works like it was designed for the car for the best of all possible reasons, the reason being that it
actually was designed for the car!
Over the years, I have done two versions of this set up on 3 of my own six-cylinder 124 cars, and on my '93 400E. On my 103 motor cars, including my current almost 300K mile backup daily driver 260E, I used 205/55/16 because I didn't want to gear those cars up. On the 3.2L and 4.2L cars I used the 215/55/16.
The reason I haven't spoken up about this possibility yet is that unless the situation has changed these wheels have not been available new for many years, and since they were not fitted as standard to any USA version car I would bet that the chances of finding a used set here are about zero, not withstanding me personally ordering and buying four sets of them between '94 and '01. And it was a 5 wheel set that I used on the 400 because I put the late version euro 400 brakes on it too, and I was not going to put myself in the position of having to change two wheels on the side of the road if I had a flat on the front...
I won't likely be in a position to check on availability or prices of these for a few work days yet, but if anyone else can, here's the numbers as they were at that time. Some of these numbers, most likely the bolts will have changed.
Wheel, silver painted version: B6 6 47 0069
Wheel, clear coated "diamond / machined" finish: B6 6 47 0087
Valve stems: 000 400 03 13
Bolts: 210 400 01 70
