  • ATTENTION
    Thank you,
    Management
FOR SALE FS: 1992 500E, Bornite/Cream-Beige, 157kmi, $16k (Warrenton, VA)
Harv
ADMIN EDIT: Price reduced to $22k. See post #12 below. Thread title updated.
ADMIN EDIT 2: Price drastically reduced to $16k BIN, per latest eBay auction.
VIN: WDBEA36E9NB786771
https://www.ebay.com/itm/401713054565 <-- Listing ended Feb-28, 2019. $22k opening bid, $25k BIN. No bids.
https://www.ebay.com/itm/401723887893 <-- Listing ends Mar-12, 2019. $19k opening bid, $22k BIN
https://www.ebay.com/itm/401752060057 <-- Listing ends April-23. $15.5k opening bid, $16K BIN
1992 Mercedes-Benz 500-Series
mercedes 500e
1992 Mercedes-Benz 500e Sedan. Porsche-Mercedes collaboration. The overall condition is good. This 500E has a tight feel on the road and is fun to drive. The exterior color is Bornite which is gray with a purple tint. This is a rare color and aesthetically pleasing. It has a different look depending on the light. The interior is a light beige and contrasts well with the Bornite.
The following mechanical work has recently been completed: lower wiring harness, alternator, starter, oil pressure sensor, oil level sensor, engine mounts, transmission cooler line, rebuilt oil filter cannister including check valve, oil pick up strainer, lower oil pan gasket, front lower control arms, struts, coil springs, upper strut mount, bumps, dust boots, rebuilt tandem power steering and rear suspension pump, transmission cooler flex line, power steering return hose, rear suspension hydraulic pressure line, purge and replace power steering and hydraulic suspension fluid, catalytic converters, resonator, exhaust flange gaskets and mounting hardware, odometer gears, serpentine belt and tensioner, battery, engine intake manifold gaskets and air hoses, rear brakes, rotors, sensors and emergency brakes, all rear suspension links and lower control arm bushings, rear hat shelf re-upholstered, assorted interior trim pieces re-dyed, and new fuel tank sending unit. The upper wiring harness, throttle body and control module and one of the fuel pumps were replaced on this vehicle a number of years ago and are in good working order. The current wheels on the vehicle are 19" AMG mono-blocks with Michelin Tires. The car comes with the original Mercedes wheels. Also included are a used trunk lid and hood to complete a face-lift to the more modern look of the 1994 E500.
The car will need some interior work including the headliner. steering wheel, rear drivers seat and door post trim sections. The dash, door panels and seats are in good condition. The exterior body is in good shape with no rust and a few very minor dings. There is a crack in the lower front bumper. The paint looks okay in some sections, but the car is in need of a re-paint. The trunk lid is the most noticeable issue since it had a poor repaint by a previous owner.
It is possible that there are other mechanical repairs I have completed and simply forgotten to list in the description. I have receipts for all work completed since 2007when I purchased the car.
Terms of Sale require a $500 deposit through PayPal within 24 hours after the close of the auction and full verified payment prior to the pick up of the vehicle.
Good luck bidding or if you prefer, secure the sale with the buy it now price.
Detailed Vehicle History
Below are the historical events for this vehicle listed in chronological order. Any discrepancies will be in bold text.
Report Run Date: 02/22/2019 18:02:07 EST
Vehicle: 1992 Mercedes-Benz 500 Series E (WDBEA36E9NB786771)
Event DateLocationOdometer ReadingData SourceDetails
01/12/1995FLState AgencyEMISSION INSPECTION
02/07/1995FORT LAUDERDALE, FL25,130Auto AuctionODOMETER READING FROM DMV
08/26/1995FL18,000State AgencyPASSED EMISSION INSPECTION
07/17/1996FL97,000State AgencyPASSED EMISSION INSPECTION
08/08/1996FORT LAUDERDALE, FLMotor Vehicle Dept.REGISTRATION EVENT/RENEWAL
09/26/1997FORT LAUDERDALE, FLMotor Vehicle Dept.REGISTRATION EVENT/RENEWAL
09/26/1997FL68,000State AgencyPASSED EMISSION INSPECTION
01/27/1998HOUSTON, TX65,440Independent Emission SourcePASSED EMISSION INSPECTION
04/06/1998RICHMOND, TXMotor Vehicle Dept.REGISTRATION EVENT/RENEWAL
05/23/1998TX65,596Motor Vehicle Dept.TITLE(Title #:22733135927094221) (Leased Vehicle)(Lien Reported)
04/16/1999RICHMOND, TXMotor Vehicle Dept.REGISTRATION EVENT/RENEWAL(Leased Vehicle)
06/14/1999DALLAS, TX91,627Independent Emission SourcePASSED EMISSION INSPECTION
05/10/2000RICHMOND, TXMotor Vehicle Dept.REGISTRATION EVENT/RENEWAL(Leased Vehicle)
02/06/2002HENDERSONVILLE, NCMotor Vehicle Dept.TITLE(Title #:776709020371022)
09/10/2003HENDERSONVILLE, NCMotor Vehicle Dept.REGISTRATION EVENT/RENEWAL
03/18/2005HENDERSONVILLE, NCMotor Vehicle Dept.REGISTRATION EVENT/RENEWAL
07/11/2005HENDERSONVILLE, NCMotor Vehicle Dept.TITLE(Title #:778157051924022)
DUPLICATE TITLE
08/22/2005MIDLAND, VA130,041Motor Vehicle Dept.TITLE
08/20/2007MIDLAND, VAMotor Vehicle Dept.REGISTRATION EVENT/RENEWAL
08/22/2008MIDLAND, VAMotor Vehicle Dept.REGISTRATION EVENT/RENEWAL
08/06/2009MIDLAND, VAMotor Vehicle Dept.REGISTRATION EVENT/RENEWAL
12/27/2013BRANDY STATION, VAMotor Vehicle Dept.REGISTRATION EVENT/RENEWAL
06/16/2014BRANDY STATION, VAMotor Vehicle Dept.REGISTRATION EVENT/RENEWAL
06/04/2015BRANDY STATION, VAMotor Vehicle Dept.REGISTRATION EVENT/RENEWAL
06/03/2016BRANDY STATION, VAMotor Vehicle Dept.REGISTRATION EVENT/RENEWAL
06/22/2017WARRENTON, VAMotor Vehicle Dept.REGISTRATION EVENT/RENEWAL
06/10/2018WARRENTON, VAMotor Vehicle Dept.REGISTRATION EVENT/RENEWAL
  • AutoCheck_WDBEA36E9NB786771.pdf
Re: FS: 1992 500E, Bornite/Cream-Beige, 157kmi, $25k (Warrenton, VA)
Too bad the paint is smoked. Bornite is super rare, right?
Also those wheels and tires are a pretty penny.
Niiiiice! I believe this belongs to a forum member, maybe he will chime in on the thread.
This car looks to have had a lot of the proper maintenance done. A fresh Bornite respray is in order.
drew
I was thinking the same thing. Most of Gerry's in-famous $10k number would go into cosmetics on this one, which would be optional - not required.
I wish the photos were high-res, not from dial-up modem days. Also need lots more pictures, including the underside.
:jono:
If anyone has any questions, please let me know. The under carriage is in good shape. There is a small ding in the back of the spare tire carrier that can be straightened. Otherwise it is clean.
Frank! Say it isn't so! :-(
The rims look great and fill out the wheel well nicely. The rims on these were refinished at Wheel Collision Center. Full Disclosure: I know these rims because they were purchased from me. Frank and I met and he got a laundry list of parts to refurbish items on his car. Looks like a lot from the list has been done.
GLWS!
Robert
The wheels on the car are actually a different set. They are Mercedes 19" AMG Monoblocks. I purchased them from a guy in California a few years ago. They definitely were not cheap. I have the set I purchased from Robert in the boxes and they are in perfect condition.
I am getting ready to relist my 500E on eBay. I have decided to take off the 19" AMG wheels and tires and sell it with the original wheels which will lower the asking price from $17,995. If anyone is interested before I relist on eBay, send me a private message or email me at ffinn11@gmail.com.
Well, my latest experience with eBay is a bit frustrating. My car sold for $15,500 and here I am 3 days after the end of the auction and the high bidder still has not paid the deposit. I have never sold on eBay before now. So far, the experience with bidders is not good. After the auction was over, the high bidder said he wanted to see the car before he made the purchase. I told him he could have inspected the car before bidding, but since he was the high bidder, he made a commitment to purchase the vehicle. I filed a claim for non-payment with eBay. Does anyone have any experience dealing with this kind of situation and if so what is the best approach to successfully resolve the issue with the high bidder.
Thanks.
Unfortunately it is becoming a "trend" on ebay. I suspect that ebay is generating some income for himself with these "successful" auctions.
When we sell a car we pay around 120-150usd which is automatically withdrawn from our bank account. Ok, I contest and what? This money is not given back to me. It appears on my ebay account as a surplus, which can be utilized in the future...
This happened to me 4 times in the last 2 month over 5 winning auctions :(
And last time I "sold" a nice 320 coupe to a Slovakian bidder, I checked his address, it was only at 80km from me, I went to say hello and nada... just a fake ebay pseudo, but with some recent activity, with 160+ positive feedbacks, etc.
Ebay must be struggling financially....
Thanks for the responses. At least I know it is not just my experience with Ebay. I have the add posted again. If this doesn't work out, I will have to try another approach.
I’m excited to say that I bought Franks car and it is on its way to California!!! Frank was a pleasure to work with and was very patient in answering all my questions and sending tons of pics. Car should be here in a few days. I’m excited to say the least. I look forward to learning from all of you as I delve into 500e ownership. Thanks again frank. She’s in good hands.
Thanks guys! Appreciate it. Can’t wait to get the car so we can get to know each other. My plan is to take care of the cosmetic issues first as the car was well maintained mechanically by frank. Once that is done, I will work on modding the car. Wheels and suspension would be first on my list to get the stance just right while maintaining and improving drivability. But let’s not get too ahead of ourselves. Gotta get the car here first. Lol
Please start an "OWNER" thread when you take delivery of the car. That way you can document your ownership through pictures and description. It's one of the favorite features of this site.
... Once that is done, I will work on modding the car. Wheels and suspension would be first on my list to get the stance just right while maintaining and improving drivability.
Lots of wheel choices available, search the forum to see what sizes / offsets / etc work.
Be careful with suspension mods. Again, there are lots of old threads discussing this. I'd generally recommend bringing it back to stock condition with new parts are required. More often than not, suspension "modifications" end up making it ride worse. You have to decide if you want to sacrifice ride and handling in exchange for "stance". I've experimented a LOT over that past 15 years on multiple different 036's and now all I do is drop the rear end slightly. If you want less body roll, buy a set of sway bars from Jono and Blue Ridge MB.
And yes, please start a new OWNER thread!
:3gears:
Will definitely start a new owner thread once I get the car.
As far as the suspension goes, i did some research and all I’m after is to lessen the gap between tire and fender. So I’m looking at H&R sport springs and drop the rear to make the car more level and not have that bulldog stance. Duly noted on the sway bars from Jono.
Lowering the rear slightly will level the car out. If you get H&R springs, it isn't easy to get it level... the front will drop too much, and the rear not enough. BT, DT. I posted a lot of details in old threads. I removed the H&R springs from that car and put stock springs back in...
Is it in your possession yet, I would like to come up an check it out someday.
Won’t Limited springs help if you want to stay OEM?
Robert
Good point, Robert. The Limited rears springs could potentially help re-sale in the future. If any spring swap is done, the originals should be kept in storage, since the stock rears are NLA now. I wouldn't be surprised if the fronts go away before long too. I'm also seeing mixed info on the Limited (#38) rears, not sure of current availability...
Man, the 036 stock springs are going NLA too? This is very worrying stuff. Why are so many essential parts going NLA - and will they ever re-appear. It appears to me that E500E partsmageddon may be in our ver near future.
