Pearl Black on Black, almost 168k miles
This was a California car, brought to Oregon, now in Tennessee.
VIN = WDBEA36E0PB851140
New upper wiring harness
New OEM ignition wires, caps, rotors, plugs at 166k miles
HVAC vacuum pods replaced in 2013
Lots of receipts from PO, well maintained by dealer and a well-known indy shop in Portland.
Transmission replaced by Mercedes of Bend, OR at 97,179 miles
Brembo rotors (all 4) at 136,000, rears drilled, calipers painted gloss black
2 lower ball joints and steering damper at 136,000
All Cam oilers replaced (metal) at 140,751 and all upper vacuum hoses replaced
PS pump resealed
AC compressor and complete power antenna replaced (OEM) at 149,896
Camshaft seals and ignition switch at 152,392
Crankshaft sensor, radiator and radiator hoses replaced at 158,174
New rear accumulators 2011
Center muffler heat shield replaced 2011
Headliner professionally replaced in late 2011
Motor mounts have been done at least once from inspection
These are just the big items amongst the various oil changes, minor switch and hose replacements, etc.
What is not stock:
Viktor 390 mm Sport steering wheel
1992 500E LH module
Euro headlamps with correct custom film covers
5 Genuine MB AMG wheels (all 9Jx18H2 ET35, not staggered) mounted in front with special hubcover wheel spacers
5 265/35 ZR18 97Y Pilot Sport tires (approx. average 50% tread life)
Full set of Cocomats in like new condition
The Sirius Radio mount will be removed. It is on a Pro-fit bracket that attaches behind the wood trim. The Pro-fit bracket is specific to the W124 and goes with the car. It too can be easily removed.
Known current issues:
Needs an inside third brake light cover (current one is cracked and taped)
Needs a front license plate filler (if no front plates in your state)
Small ding on right rear, near tail lamp
This car, for the mileage, is by far, one of the nicer examples of a driver, not a garage queen. All maintenance is up-to-date. This car is ready to cruise.
$14,750 (price reduced on April 25, 2014 from $16,750--> $15,750, again May 20 to $14,750)
High resolution photos available at: https://www.dropbox.com/sh/fye7l4zmiv4o1cx/1qAc3c6kIw
PPI encouraged. I would enjoy delivering to most locations for gas money and return airfare.
Contact here or via phone/ text or email at dlandaeta at gmail dot com 908 803 3551
PS pump resealed
What is not stock:
1992 500E LH module
