To check shifter bushings, put the lever in "D" position and gently press forward/back. There should be ZERO play. If there's any play, one or both bushing are shot. Cheap to replace but an hour or so of DIY labor. Details at this link if you need to replace them.
Thanks and much appreciated.
Just had bushings done and new wooden gear shift knob.
Not sure where the switch is?
There is a piece of metal that blocks the shifter from coming all the way down to 2 so can’t get down and over right to B.
have pulled the shift knob down to try to pull it into 2 but metal doesn’t move.
Thoughts?
Sounds to me like someone moved your B switch over to the right. Use something like a screwdriver to reach into the slot and click the B switch back to the left so that it looks like GSXR's photo. Then your shifter will slide into it and you can use the shifter to move the switch to the right.
