Ok...here is the story :
-cold start : engine starts right away ( less than 1.5 seconds ) and drives great!!!
when I drive to the supermarket ( or anywhere) and engine reaches temperature, the car will have a hard start ( 2.5 seconds) and acceleration will be a little slugglish until 40 mph.....then it will drive fine.
Car runs great on highway.....only issue would be when I stop for gas : hard start again and a little sluggish.
Test that I did : after hard start and stopping at a stop sign ( or traffic light ) , I would hold the brake pedal with left foot and give a little gas with the right foot (1000 rpm or so) : Car won't get sluggish.
idle is fine in neutral and in drive ( same as before the issue)
I tested fuel pressure at idle : awesome and within specs!! FPR as well.
switched throttle body : NO change ( selling the one that i remove, btw)
NEW fuel filter : NO change
NEW FPR : NO change
check the engine temperature sensor : seems to be in specs as well ( 323 and 326 when engine is under 80 degrees....can't remember values when engine was around 90 , but they were in specs too)
Cleaned spark plugs : NO change ( definitely NO gas on them)
newish caps , rotors, ignition coils and thingy behind the rotors are fine ( dry as it can be )
spark plugs wire are also newish.
NO smell of fuel in the car or under the hood
Fuel injectors seems to click the same ( used the screwdriver method)
NO misfire, NO rough idle...
put a bottle of redline SL 1 : NO difference
wiring harness in NOT the shitty ones
If i unplugged the MAF, there will be a little drop of RPM just when i unplug, but the car will compensate and idle fine again......
NO vacuum leaks
Car runs great on hwy with great acceleration ....kickdown works great too...
MPG is good ( 25 mpg yesterday on hwy for a full tank at 70-72 mph....with ac on most of the time)
Basically, I don't understand the issue!!!!
Any ideas???????
Would a bad check valve on one of the pumps cause hard starting when engine is warm???
NEW FPR : NO change
NO vacuum leaks
Any ideas???????
