Cool - replace the 4 pods that require pulling the dash (center vent, 2 main air flap/recirc, and diverter if you can still get one).I already have the lower dash taken off, and was planning on taking the upper dash off as well to make sure there are no more surprises. So that could work, I can probably create some elegant homemade fitting to cure the connector woes.
Assuming you mean the function of the plastic piece that broke, it allows a rubber hose to fit on either side. No need to pass through a tube or hose.What is the function of this vaccum anyway?
I believe the Klima kits are primarily for the 126 chassis - not sure if those kits work with the 124 pods. The Murphy/PP ACD-2010 diaphragm will rebuild the center vent pod 100%. The ACD-2010 kit will rebuild half of the pink dual-chamber pods, and ~90% of the time, that's all you need (the other half is usually fine). The diverter pod is NLA and there are NO repair kits available, it's smaller diameter. This one is usually ok, so you can leave it alone if you can't find a NOS diverter pod.As for the pods... Are the Klima rebuild kits good? I saw Gerry mention them here, but I'm unsure if I'm looking at the right thing.
OH! Sorry, I thought you knew... that is for the center vent pod. No vacuum means the center vent never opens, you do not get cool air out the center vents in cooling mode. The center vent pod is NOT fun to access or replace. Search the forum for details on repair & replacement.I know that the vaccum goes through, lmao!
What does that vaccum specifically DO? You know, it being broken - what am I losing? Just asking from a pure curiosity standpoint.
Yup... make it 4 diaphragms if you want to do the defroster flap pod while you're in there. The defrost pod can be access through the glovebox / passenger airbag opening, but it's way easier with the dash off.Jokes and curiosity aside, looks like I need to reach out to PAC. Just 3 diaphrams given the diverter pod situation?
It's NOT fun.How on Earth do you get this pod out? I read through some of the documentation on here and elsewhere, the holes are so small I can get like 3 fingers in there.
 But, it's possible.
 But, it's possible.
I never did test "on the car" to verify how much this affects movement of the flaps. However I suspect it will not allow the flaps to move through the normal range of travel. And, this is why I've been dissing those -2020 kits ever since I figured this out many years ago!Oh my god, it literally is half, that’s what I thought! I figured it would have been a good replacement to do. I cut up pretty much a perfect rubber piece.
What the hell is the point of the replacement if it literally only works half way? Now I’m going to have half vent control???
Yup! All the "pink" pods on the 124 are interchangeable, if you swap the metal arms. In some cases you miiiight need to re-clock the pod to get the vacuum ports in the correct position relative to the mounting bracket. But the pod itself is identical.If I got this pod, I can just interchange the springs and arms and it should work good as new?
I was thinking as a cost savings, put the new ones where they're hard to access... and a good used one where you can easily swap it in the future. If it's in the budget, all new is always preferred!Dash is already out homie! This was going to be part of putting it back together, lol.
There is also this one in Indonesia for like $50 and at least a week of wait.
Ah, interesting... I did not know that. I have a new one of each on the shelf somewhere, I'll try to measure the travel.There is some difference in the pink pods. The ones by the firewall have less travel and weaker spring.
Great info - thanks for confirming! I wonder if one of the flaps requires more pressure to close?I had two different pods open and the springs were different, by the way. One had more coils.
