94 E500
AC intermittent. Seems to always work on cold start but intermittent when car is hot. When AC not working, compressor is not engaged. Verified function of low speed cooling fans. Suspect faulty relay in base module. With hot car, engine running and AC commanded on but compressor not engaged, opened module box to “tap” on base module. No effect on compressor engagement but noticed electronic modules very very hot to the touch.
Is it possible that high temp in module box is causing faults in compressor relay function?
I noticed cooling air plumbing entering box. Not sure but I can see what looks like a blower attached to end of air plumbing. Anyone know air flow path for blower system and how it can be tested?
Thanks.
J. M. van Swaay
Thanks.
J. M. van Swaay
