Left line from oil cooler
timpurister
Hey
I have oil cooler 140-500-00-00 installed and the left line looks pretty worn. I have been looking for the part number without success, does anyone happen to know it ? It looks somewhat aftermarket hose to me but my friend has similar so I think it is ok. We are taking the engine out so thought that I should replace all the stuff necessary while in there.
Thanks already
Timo
The part number was superceded to a 2-piece hose assembly, but they are all NLA. Yours appears factory original and correct.
Are you certain it is leaking? If not, leave it alone. If you are worried about it failing, have a hydraulic shop rebuild it with new rubber hose. Same with the other side.
FYI, the oil line A1191801082 is actually available and I have it now. I took the old one to hydraulic shop and they said it the can replace the line but they did not have a new end to it so they said they need to re-use the old one.
