Vacuum line
Se3K
E500E Newbie
New Member
Newbie here I was wondering if anyone can be kind enough to guide me on where this line needs to be connected. Picked this project up as it my dream car as a kid and well I’m trying to get her going. Any guidance is highly appreciated.
There is a full vacuum diagram that should be on a sticker underhood, no? If not, there are numerous references here for it.
That vacuum line should go down behind the engine, to the round plastic vacuum modulator on the driver's side of the transmission.
Image is copied from another post here. See #53 in the diagram below.
intake-manifold-leak-jpg.217411
What is the correct way to route the line from #35 to #8? Also is the tubing Mercedes Vacuum Line 1x8mm - Cohline 0009872727?
This 8mm tube routes through the intake manifold, and exits near where the engine serial number is stamped on the block. Then it runs below the distributor cap and over to the purge valve near the EZL.
Thanks Dave. So it kind of makes a loop back towards the serial number? Also is the correct part 0009872727?
