“Whistle” noise from engine when engaging WOT
Matin
Hi All
Hope everyone is well.
I’ve recently developed a symptom on my 500E, when I engage WOT / kickdown, I get a “whistle” type noise from the engine.
I’m not sure where the noise is coming from exactly - it doesn’t happen when you just rev the engine normally, it always happens when WOT / kick down is engaged.
Has anyone experienced this before? Anyone have any ideas?
My first thoughts are it may be some of the lines connected to the MAF? Could this also be belt related?
Thanks!
Bumping the above - anyone experienced an issue like this? I did a smoke test, I found one leak where the transmission vacuum plugs into, patched that up, but the “squeal” noise still persists and it’s only from 0 -> WOT or very low speed to WOT.
Could it be the serpentine belt?
Best
I’ll throw this out there FWIW—The insulation on the zoom tubes is ostensibly there to dampen the noise of the air traveling through them at high power. Are yours in good shape, installed correctly and not leaking?
