Hello,
Hopefully I can get some het from the Forum.
My car was in storage for a couple of years (1992 500E). When I stored the car, everything was working perfectly fine. Once out of storage, engine would only crank but not start. It ended up being clogged injectors. Details in the thread at this link.
After replacing all 8 Injectors, engine starts up perfectly and runs great in idle. The problem I am having is, as soon as I accelerate, the engine lacks power and stalls out. If I let go on the gas pedal engine runs nice and smooth in idle. I barely made it to the gas station and back. I am pretty sure it's not misfire.
Since my fuel system was contaminated, I replaced the following parts: 8 Injectors, 2x Bosch fuel pumps, Bosch fuel pressure regulator, fuel filter, drained the whole tank and filled with fresh gas.
Other maintenance items replaced: All spark plugs, air filter, Beru Wire Set, Oil and Filter. Removed caps and rotors multiple times, they look good. I replaced them roughly 2k miles ago with Bosch parts. Upper engine harness was replaced in 2015. Checked compression, chain timing ok. Fuel Pressure is good. No high back pressure. Disconnect MAF sensor, same thing, engine stalls. With my blink code reader, no codes in system. Smoke tested intake manifold, no leaks.
I feel like it's not getting enough air... could the throttle body be defective?
Please see video below, once the RPM goes up, engine just stalls out. Any advice is appreciated
