“Whistle” noise from engine when engaging WOT
Post number 5 has been selected as best answered.
Matin
Hi All
Hope everyone is well.
I’ve recently developed a symptom on my 500E, when I engage WOT / kickdown, I get a “whistle” type noise from the engine.
I’m not sure where the noise is coming from exactly - it doesn’t happen when you just rev the engine normally, it always happens when WOT / kick down is engaged.
Has anyone experienced this before? Anyone have any ideas?
My first thoughts are it may be some of the lines connected to the MAF? Could this also be belt related?
Thanks!
Bumping the above - anyone experienced an issue like this? I did a smoke test, I found one leak where the transmission vacuum plugs into, patched that up, but the “squeal” noise still persists and it’s only from 0 -> WOT or very low speed to WOT.
Could it be the serpentine belt?
Best
thank you all who responded with suggestions.
To provide an update on anyone else who experiences the same issue - I changed the serpentine belt… I last changed it back in 2017, although it looked fine, no visible cracks, tearing, etc, the “squeal” on WOT has now gone and the engine back to being noise free.
Matin
