Hi guys,
I have been scouring this forum trying to find some input to my problem and have found similar issues, but the remedies to them have not fixed my problems....
On my 1992 500E, I have a long warm start issue that occurs immediately after turning the car off. What I mean by that is it doesn't matter if the car sits for 5 seconds or 30 minutes, when warm, it still has a long start. I thought this could be the fuel pressure regulator, which I replaced a few months ago, but was worried it could be defective. Replaced again and no difference. Additionally, both fuel pumps (with new check valves) and fuel filter were replaced shortly before the long start occurred. The LH module has also been replaced to fix a long cold start issue (fuel pumps wouldn't prime during cold start, causing a long and rough start. Module fixed the cold start issue). I initially though maybe one of the pumps was bad, so I replaced both to still have the same issue... swapped with the LH module for my 94 E500 and it would start right up when cold.
Thinking maybe the used module I got fixed the cold start issue but created the warm start issue, I swapped the old module back into the car (never had this issue with that module installed, only the cold start issue) and the long warm start still occured. Additionally, I disconnected the MAF sensor and the long start still occured, but was somewhat intermittent. It started regularly only once with a long start every time otherwise, but then when I reconnected the MAF it started normally again as well, therefore I think it may be unrelated to the MAF itswlr and could be just a fluke event where it actually worked as it should.
I have attached a link to my youtube video showing the long start. This is after idling the car in the driveway for roughly 10-15 minutes with about 80° temps outside. It's an odd long start because it doesn't stumble or run rough when the car does finally restart. It like a switch is flipped and then the car fires up after maybe 3 or 4 seconds and runs perfectly.
Thanks in advance for the advice!
Owen
Long start video link -
Owen
