I've removed my cluster for some cleaning and repairs, and after plugging it in - I have noticed that my SRS light does not behave the way it should!
What is happening? It does not light up at all. However, if the cluster isn't pushed in all the way... the SRS light will emit, and will not go away (fault). In some positions it will work and light up, then when I hit a couple bumps on the road, it seems to lose connection completely again.
So, I am assuming two things:
1. The connection to the SRS module (?) is loose or corroded and needs repair.
2. There is a fault in the SRS system that is throwing the light, which I'm sure I can diagnose.
Now for my question:
Where can I follow the SRS light bulb to? To my understanding there is an SRS module under the radio. Could this be where this SRS light bulb wire is going?
