Lower Windscreen Trim
DarkStar
Does anyone know if the lower trim (2 pieces) on the base of the windscreen is currently available? The pieces are clipped on and seem to be rubber covered thin metal pieces about 4cm x 50cm they also have separate rubber trim piece that fits in a groove. I had a few leaves in mine and decided to take it off, the rubber is thin and has a few areas that are pretty dry rotted. Also found. a clip that was missing underneath. It rivets to the cowl below the windscreen.
If not currently available I am not certain how difficult it might be to make something or refurbish the OEM piece.
If you are referring to the early style trim pieces, used through late 1993 USA model year, they were still available new last time I checked.
1246711330 and 1246711430, ~$60 each MSRP.
